Dave merrill and "D" grader
Charles Craig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles Craig Quote  Post ReplyReply Direct Link To This Post Topic: Dave merrill and "D" grader
    Posted: 01 Dec 2009 at 8:34am
  This is to introduce a new member that I think needs a special HELLO.  Dave is the Park Ranger for a Boy Scout camp in Pleasant Valley Utah. He has five miles of road to grade to keep the facilities open. All of you that own this model machine already know its too fast to grade efficiently. The Boys would appreciate all the help that is needed to accomplish Daves needs. Put on your thinking caps and give Dave a helping hand.  Charles Craig  Ex scout leader and Two Eagles in family   THANK YOU
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
AC BD3 roadgrader "D" road grader SIX "old" cars Farmall 300
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 6:26pm
Charles, several years ago I built my oun grader. Its made from a WD, I lengthened the frame , made a 10 ft. blade that power angles. Besides my 1/4 mile drive I hire out to do about 4 others plus the Church parking lot. It is a cheap outfit and fun to use, plus its orange!  HTH  Mark L
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 11:58pm
Dave, it may be a tall order. I have made similar requests in the past few years and have not had any success. I keep hoping that I will run across a parts machine with the auxiliary transmission. In the mean time I just make do and end up running the engine quite slow in tight situations. It is still capable of spinning the four drive wheels even at a fast idle. One option that may be a slight help is to buy the smallest diameter tires you can that will fit your wheels. The drive tires should be all the same size as these graders do not have a differential. All four drive wheels are locked together.
A couple of years ago someone took out their crown and pinion gears. One responder to that post said that they were a weak point and they thought that the crown and pinion were common to some truck rear end. Unfortunately this was never confirmed but if they were common to a truck rear end it might be possible to to get a different ratio that would slow it down.
