226 oh kits
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: 226 oh kits
    Posted: 29 Jan 2012 at 3:49pm
I noticed a high compression flat top kit is offered for the d17/170 but I don't see a high compression kit for the 45. What's the difference? 17 crank has larger main journals correct? Anything else?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 4:05pm
In the WD/WD45 parts book, the 5.5 compression ratio WD flat top piston carries the same number as the WD45 7.2 for LP.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 4:47pm
 I can help  with 4.125  flat  top  or  4"  flat  top   sleeve  kits. Tony    1-877-602-3994
This page was generated in 0.742 seconds.
