AC drive sprocket wanted
Dave Merrill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Merrill Quote  Post ReplyReply Direct Link To This Post Topic: AC drive sprocket wanted
    Posted: 30 Nov 2009 at 7:59pm
Looking for a pair of AC 9 tooth drive sprockets p/n 646974 for D motor grader, new or used.  Any suggestions welcomed.  Where is the best place (s) to look for used motor grader parts?
Thanks,
Dave Merrill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 8:59pm
Depending on the size of the chanin that runs on them and the bore ?  You might be able to get a stock sprocket with open bore and weld to present  hub.
 Check with some bearing houses for these units.
