HD11 TRACK REMOVAL |
Argo2
Topic: HD11 TRACK REMOVALPosted: 29 Jan 2012 at 10:00am |
I need to remove the left track on my HD11. Is there a master link on the track and if so what am I looking for. What kind of a job (besides being heavy) is this going to be?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 29 Jan 2012 at 12:39pm |
two types of track , one with a master pin which should have a mark on end -circle or O with pin prick in center or a slight taper and a little longer than rest of pins. master link also has a shorter bushing and on inside of track link are washer and shims to take up space of shorter bushing .
Other is a split link that the track bolts hold together and which has teeth that interlock to create a strong joint. On this type the track plate is removed and link splits in half. Bushings are same length in all links.
Steve allis dozer
Silver Level Access
Joined: 10 Apr 2011 Location: Australia Points: 232 |
Posted: 29 Jan 2012 at 6:36pm |
I have taken the track chains off and on my HD11 in one piece using an excavator and chain to do the lifting , remove blade , remove track udjusters slide front idler right back jack track frame up a bit and remove from the side, the master link pins take some geting out!
