|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| 190XT Dual Hubs |
| Post Reply   |
| 190XTJR   Bronze Level   Joined: 14 Feb 2010 Location: central, MN Points: 14 |  Post Options  Thanks(0)  Quote  Reply  Topic: 190XT Dual Hubs Posted: 27 Jan 2012 at 9:18pm |
| Hey guys I just bought my first AC, a 65 190XT it has had the rearend updates to large bullgears and large axles with 38 inch rear rubber. I was wondering how hard it is to find hubs to fit these axles so I can run hub duals. The reason I want to run hub duals is it is alot easier to find 38" hub dual rims verses 38" band duals around here. I will try to get pics up these weekend of the 190 and the story of this tractor. Thanks, DuWayne | |
| Calvin Schmidt   Orange Level     Joined: 11 Sep 2009 Location: Ontario Can. Points: 4555 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jan 2012 at 9:27pm |
   Your axles may not be long enough to mount an axle hub for duals. You need the A-C 'flower pot' cast adaptor for duals. It bolts to the 6 holes in you cast center and has a 9 bolt pattern for a standard dual rim.
| XT in pa   Orange Level     Joined: 21 Apr 2011 Location: hickory pa Points: 711 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jan 2012 at 9:53pm |
   Calvin I put them on my 69 series 3 they worked fine.  they are not spaced for row crop tho  I will try to remember to get measurement this weekend. Are yours spin out or bevel rims.                   Shawn
     190XT,D17and 7045
| 190XTJR   Bronze Level   Joined: 14 Feb 2010 Location: central, MN Points: 14 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jan 2012 at 9:57pm |
   I have the spin out rims. How easy is it to find the flower pot hubs and what are they worth?
| XT in pa   Orange Level     Joined: 21 Apr 2011 Location: hickory pa Points: 711 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jan 2012 at 10:03pm |
   Flower pot hubs I don't kno either  I have only seem one pair on my uncles .my hubs came with spacers and I didn't use them bout 8 inch or so the spacer bolts to hub and duals bolt to spacer . The ones I got are from a 200 but they are the same . They cost me 75 for the pair
     190XT,D17and 7045
| ILGLEANER   Orange Level Access   Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jan 2012 at 10:46pm |
    I have the flower pots, or the hubs for your 190.  PM me.
                                         IG | |
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
