Anyone own or seen a All Crop 72 with corn head ?
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Topic: Anyone own or seen a All Crop 72 with corn head ?
    Posted: 25 Jan 2012 at 9:38pm
   Wondering if any of these still exist ? Were only 100 made. Would love to see a picture of one in the present day, if any are still out there ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 9:47pm
Was there one at Rantoul? Or was that a 90?
I think that was a 90 at Rantoul. Here are a few photos I dug up.
Edited by Pat the Plumber CIL - 25 Jan 2012 at 9:58pm
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 9:48pm
I saw an All Crop 72 with corn head sold at a farm auction Nov 11, 1967. I purchased the D17 series I tractor for $1850.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 10:02pm
   Pat, that is Marion Klutzke's 66.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 10:18pm
Thanks Randy, did not think it was a 72
JimIA View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 11:02pm
The only time  I have ever seen reference to a 72 with a corn head was a number of years ago in the Allis-Connection classifieds.  I think it was in the late 90s.  I just remember seeing it and wishing I had the money for it!
Jim
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 10:12am
The guys at R&R equiptment had a pull type with a corn head on it.  I cant remember if it was a 66 or 72.  I had corn next to their operation 1 year and tryd to get them to let me use it.  I didnot get to use it.
Regie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 3:36pm
Just asking, to use the corn head you have to take the reel and all its attachments off.  Which means there should be an easy way to do that/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 5:23pm
   Regie, are you wanting to take the reel off or take it apart ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 6:24pm
i've taken the reel apart.  The Sheave (pulley) appears to be married to the shaft,  Thewr was no set screw in it and it will not budge.  The next idea was to take the whole assembly off.  There"s a rod (threaded at both ends) at the base of the reel bar and reel bar brace that holds them in a bracket.  Got the impact wrench out and got the inside Not off but the the rod does hot want to pull out.
The reel shaft is bent and we were thinking we could get a piece of steel tub the same diamater and make a new one,  hubs the real attaches to are welded to the shaft.   I don't think the hub the sheave is bolted to is welded to the shaft but I'm not sure how is attached.  There is some kind of pin or ring inside the shaft on that end I was wondering if there was some way of pinning the hub on from inside the shaft.  My son thinks the hub might be welded on but I cant see any evidence of of it being welded.  You can see orange paint inside the set screw hold so I don't think there was ever a set screw in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 6:26pm
Als I was thing about trying to get a corn head and wondering how big deal it was going to be to switch back and forthe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 6:45pm
   The parts book shows there was a setscrew in the hub of the belt pulley, it also is keyed to the shaft. Have you tryed heating the hub up ? Probably going to take some heat to get that rod on the brace out to. How bad is the shaft bent ? You might be able to straighten it out without taking it apart if you put some heat where its bent and do some tweaking.
   As far as a cornhead, they are hard to come by. And they basicly went on the combine and stay there. You didn't switch back and forth. There are also additional parts in the rest of the combine that make them different from a regular All Crop.
Edited by Rfdeere - 26 Jan 2012 at 6:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 7:01pm
I looked at the parts catalong and the assembly catalog before starting on the reel.  The hold hub area was coated in old grease.  After getting some of the grease off I found the no set screw thing.  I'll probably end up getting a torch to try and heat it with.  I Ton't think the shaft is badly bent and I may try and straighten it.
patrickmull View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 7:10pm
there is one at this auction  http://www.knowlesauctions.com/ in march it is on a 60
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 7:36pm
   Patrick, I am going to make a separate post for that sale. Some good stuff on there !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 5:22pm
   Bumping for new eyes to see.
