C clutch spring question
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Topic: C clutch spring question
    Posted: 25 Jan 2012 at 1:33pm
I was wondering if someone could help me. I think the return spring on the clutch foot pedal is hooked up wrong (see photo). Could anyone explain to me where the two ends of the spring are supposed to be hooked to?
Thanks!
1953CA View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2012 at 3:21pm
The cotter pin on the clutch actuating rod is right, now the other end of the sring is suppose to be in the hole on the clutch pedal itself, under where the actuating rod is.  Also you have the wrong spring.
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
This page was generated in 0.085 seconds.
