262 DIESEL PROBLEMS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: 262 DIESEL PROBLEMS
    Posted: 30 Nov 2009 at 11:16am
Just talked to the machine shop that has my D17D head and they say that 4 of the pistons are hitting the head. 4 of them are clean on top and I thought the reason was from coolant washing them clean since there appears to be nothing imbedded in the pistons. They tell me they can offset grind the wrist pin bushings up to about .005. This is new territory for me. What now? Have the bushings offset? What about shaving the tops of the pistons? Where should the pistons be from the deck of the block at TDC?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 11:31am
Has the engine been overhauled?? Maybe it has the wrong pistons. I would look into getting a new set of pistons, or maybe call Bill or Brenda at Sandy Lake andd see if they can give you the spec, then you can pop the 4 pistons out and mic them and see if the pin boos is in the right spot.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
1968 D15D,1962 D19D
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 12:47pm
4 pistons hitting the head??   You better tear the motor down alot further, something sounds terribly wrong. I would say something with the wrong pistons on 4 holes. I have a 262 gas apart at the moment and all the pistons are about 3/8' below the deck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 1:27pm
The engine is coming out to take a closer look. I'm about 99% sure it's been overhauled, but it sat for a long time and the sleeves got rusty. Now they're all pitted. Me being a professional mechanic, I can't leave it that way, so I was thinking if all is well below, I'd do an in frame overhaul on it. I have noticed there is a range of serial numbers on some on line sites that use a different part# other than what must be common. I guess what I need to know is what is the spec for piston to head clearance. I figure I can measure the clearance with clay and tightening the head down on the old gasket and then measure the thickness of the squeezed out clay. That's how engine builders measure valve clearance to piston on hi-po racing engines anyway.
Matt, is the 262 gas head flat with no combustion chamber like a 226 and 201 4cyl head? If it is, that would account for the distance below the deck to lower the compression ratio for gasoline.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 4:01pm
On that engine the pistons do come above deck height, so head gasket thickness is critical.  I'm going to do this from memory so don't hold me to it, but the number I remember is .021" above deck maximum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 4:47pm
Thanks Ted. I'm going to do some measuring tonight. I have a Fel-Pro head set. I'm also going to try the clay depth measuring test to see what I get. A while back someone posted that they had a custom copper head gasket made form a place in Texas I think.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 4:50pm
Gasket Works USA,LLC. copper@headgasket.com for custom copper head gaskets
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 5:45pm
....BRIAN   There are several different thickness of headgaskets available from Agco.  Ck your serial # and make sure the 1 you have is right for your tractor.  Mine was replaced with the wrong gasket and it cost me a complete overhaul.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 5:53pm
Tom, What happened? Bend rods, break pistons? How will I go about determining the needed gasket thickness?
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 8:51pm
My question is why are 4 out of 6 different from the others? Cyl. run out is critical on the 262's for proper head gasket seal. The piston run out will determine compresion and result in a clean, good starting engine or one with low compresion that your never fully satisfied with. Still, why are the 2 not matching up to the other 4.
Sounds to me that a complete engine kit is needed and decking the block, cutting new counterbores for the cyl's, and turning the tops of the pistons to correct the runout may be needed to do it right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 9:46pm
Rod bearings are worn on the 4 pistons causing them to hit the head when the rpm's are up. Pull the pan and check the bearings.
 There are 2 different head gaskets, a .035 for gas and a .065 for diesal.
   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 6:05am
Before the head gasket issue, this engine would start without any help down into the 30's. Some other thoughts I had were if the engine ran away once and the rods stretched. It does have dents from the inside of the pan and a hole that has been brazed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 6:29pm
I measured the old gasket .055. New gasket .066. I measured the stand out of a couple pistons. 1 of them was .060 the other .050. I guess it's down to block having been surfaced excessively, wrong pistons, or stretched connecting rods.
This page was generated in 0.123 seconds.
