Cold Cranking Amps
MoDoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoDoc Quote  Post ReplyReply Direct Link To This Post Topic: Cold Cranking Amps
    Posted: 22 Jan 2012 at 10:22pm
Have a  Aggo Allis 5670. Replaced the battery with a non OEM battery. Has 850 CCA. Will not turn over fast enough to start in cold, below 25 degree, weather. Does anyone know how many amps are needed? (4 cyl. diesel)
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 10:50pm
I would think a 900-1000 amp battery would do fine. Yours is a tad low but I'd think it should spin it up as long as cables and starter are in good shape. While cranking under load feel for any warm spots in cables or connections. Heat will show up as wasted current and will reveal a troule spot. Also you may not be getting full load amps out of the battery. I'd have it checked reguardless of it being new.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 11:46pm
With a single 850 CCA battery I can start a DT 466 truck engine , the Perkins in my 715B , the 2-71 in HD5,  but all of them might need a shot of either to aid in starting much below 25F. in fact the Perkins at 30 needs a shot. On my old 785 NH skid the Perkins in that would start down to 0 without either using a single 850 CCA battery.
 My FD5 using 2 of those 850 CCA batteries for 24 V started with no aids at -10F , that Fiat 4 cyl engine is surprisingly good starting engine .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 6:35am
I would think your 850 CCA Battery would be boarderline for the application. If the engine has a block heater and it's plugged in on the wicked cold nights, that 850 still may stumble a bit getting the engine turned over. It may get the job done with the heater helping, but still on the low amp side. Usually, if you can supply a 1000 CCA power supply, you'll have much more success in turning over a Diesel in the low low temps. Its much easier on the starter motor also.  HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoDoc Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 11:39am
Steve@B&B
I don't have a block heater. I do have the ether button for manual injection, but when the temp drops, the battery will only turn over to slow to fire. Guess I'll look for a 1000 or 1100.   thanks
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 11:48am
Get a block heater and throw the either away .. you will be glad you did ...
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 11:50am
cold cranking amps is the amperage rating the battery can deliver for 30 seconds at 0 degrees f . on thick diesel probably not enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 12:00pm
Guess I should say I buy the largest Automotive battery I can find , some were rated at 1100 CCA but when you read the fine print they are 900/ 950 or even 850 CCA at lowest temp.
 I use the same batteries in all my vehicles and equipment, from dump truck, pickup, to dozer. Duel terminal ones with both side and top posts.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 1:29pm
What oil are you using??
You might consider Mobil 1 5w-40 diesel oil.  If you are using a 15w-40, the 5w-40 will make a big difference in cranking speed and no difference at operating temp.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoDoc Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 2:51pm
Time for an oil change anyway. I'll try the 5w-40
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoDoc Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 2:59pm
The 5670 is an air cooled engine. The manual talks about an optional heater. Something about a air chamber heater. Don't know much about it. Sounds like it would not warm the oil and cause it to spin easier. I do have the glow plugs, but again with a wimpy battery, by the time they are warm the battery is spent.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 3:14pm
As said first check your cables and clamps.  Bigger really is better in battery cables for diesels.  try putting a big set of jumper cables from battery to starter to rule out voltage drop from bad cables.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 4:35pm
First off, have a 5660, had a 5680, and I know exactly what you are talking about.  The heater, in the intake manifold, is electric and sprays diesel fuel on the heater element, you have to wait till the light goes out on the dash, by this time you have one shot to get it going or else no more battery. BTDTB.  The original battery is like 1250 CCA, only available from AGCO or SAMI, I priced one and they wanted more than $300 for it.  Instead I put on a 1000CCA battery out of my Freighliner for the time being,  it did not fit under the cover behind the seat on the 5660 too well so instead I put two 750 CCA batteries that did fit under the cover with one on a mount on top of the roll bar support.  When they went I went back to one truck battery (same as the Freighliner one I originally tried) and have not had a problem since.  In the between time though I had put new injector tips on and when we dynoed it it only put out 32 hp after an adjustment to the governor it has never failed to start, funny thing is it never ran the way it does now when it was new, always started hard but now it is a new tractor, it will smoke when you get after it and it has 55 hp on the dyno.  Wish we had put it on the dyno before we bought it, I am sure it would have had no more than 35hp new.
It now starts without the pre heater down to -20 C, and has a little over 5500 hrs on it.
Edited by Amos - 23 Jan 2012 at 4:37pm
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 5:09pm
Leaving a trickle charger on the battery will increase cranking power a bunch!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoDoc Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 4:34pm
Clamps are good and clean. I'll try the jumper cable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoDoc Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 4:35pm
do you think it was the new injector tips that made the difference or the bigger battery or both?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoDoc Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 4:38pm
Will end up doing that, but it is a nuisance to take off the side cover to get to the battery. I wonder if attaching some cable extensions and bringing them outside of the cover would solve the problem. That way you could hook up a charger without taking off the cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 7:43pm
Some trickle charges come with a harness that can be connected to the battery and ends in a plug of its own.  The plug can be put in an accessible location that the trickle charger can then be plugged directly to.
Mark
GTH-L Simplicity
ICTRCTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICTRCTR Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 7:50pm
  What arre the cold cranks rating based on, cca at 32 degrees or at '0' degrees
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 10:35pm
I have two 1000cca batteries on my D17D. I also have 00 gauge cables. You can do a voltage drop test and find any connections that may be lacking. Parallel each cable with a volt meter and crank the engine. Shouldn't see more than a couple tenths of a volt on the meter. Measure more than that and you have high resistance that needs attention.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 10:37pm
"Cranking Amps" are measured at 32 degrees. "Cold Cranking Amps" are measured at 0 degrees.
This page was generated in 0.227 seconds.
