Circuit Breaker-8550
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Topic: Circuit Breaker-8550
    Posted: 22 Jan 2012 at 3:58pm
Does anyone know where the 6 amp and 30 amp circuit breakers are located in the cab. These are not the ones in the dash area but the ones that run the headliner switches (stadium lites, remote mirrors etc..). I took out the stadium lite switch module and the right speaker but not there. The manuals talk about them but don't tell you where they are. Thanks
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 4:18pm
I think between the heater and A/C control knobs?  Should be able to see screw heads from the seat to know where they are located.  I think you have to remove cab top to change them.
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 5:15pm
Thanks Russ. You're correct on the top take-off. That seems like strange engineering planning. Been told while I'm in there to lub up what needs it.
