Help identify engine please
sawzall5150 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sawzall5150 Quote  Post ReplyReply Direct Link To This Post Topic: Help identify engine please
    Posted: 22 Jan 2012 at 12:07pm
The distributor on my forklift  quit spinning  and I can't get it to come out so I can inspect the problem. I can pull out about 3/4" and feel it "clunk" against something solid. The Forklift is a Allis-Chalmers FDX80-24. I've been told that the X denotes diesel but is a 6 cyl propane.It has to be the propane engine for that model because it fits like factory. The engine has absolutely no tags or markings of any kind. When I run the distributer part number on the delco-remy website it says obsolete and says it's for a 4 cylinder. If I could at least identify the engine I could get a distributer somewhere. So far I can't even get out the distributer. The forklift is old but in very good condition, lowhours, we use it every day and can't be without.n Any ideas?
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 2:36pm
Can you turn the distributor as you pull it up. I can't think of any reason that it shouldn't come out unless there is some built up deposit in the casting or worst case a broken cam section. Try pulling the valve cover and see if all the rockers are moving. This will show a broken cam if they aren't moving. You'll need to snap a picture of the engine and some details before anyone could guess the engine. Most AC lifts had several engines avaliable and it's possible it has had an engine swap in it's lifetime.
Yea, I can fix that.....
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 4:20pm
The engine will be the A-C (Buda) 230 or 262.
This page was generated in 0.186 seconds.
