how to change wd from 6volt to 12 volt.
AC220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC220 Quote  Post ReplyReply Direct Link To This Post Topic: how to change wd from 6volt to 12 volt.
    Posted: 30 Nov 2009 at 4:22am
I want to change are wd from 6 volt to 12 volt and I need to know what needs to be installed and changed over. thanks guys.
7080,7040,220,185,&6080 FWA that was sold to Larry Karg.
StanInLowerAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 6:02am
I made this change with my B, but did not change from points to electronic module.  I used a CS 130 alternator (voltage regulator no longer needed), 12v coil and lights.  I also replaced the amp gage with a volt gage.  Something to stop the current flow to the alternator when the engine is stopped will be needed to keep the battery from discharging (I used a small signal light wired into the exciter wire line).  I kept the 6v starter, but had it thoroughly checked before using it.  I also changed to an electric solenoid switch for engaging the starter (more safe than a pull rod around kids).  Since I had to entirely rewire it, I chose to use neg. ground.  Here is a picture someone had previously posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 6:08am
I might should have said that the diagram shows a resistor and 6v coil.  It is not clearly marked on the drawing. Sorry.  Steve at B&B has great setups for this conversion as well as instructions and extensive knowledge as to what it takes to make the change safely and trouble free.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 7:25am
I used one of of Steve's kits, it is really slick, comes with complete instructions and it totally complete right down to the silicone grease for the connections.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 7:39am
My question is WHY?  Use the correct battery cables, and keep them clean and you are fine.  I can start my WD45 at -20 on six volts.
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 7:52am
I've got a nearly brand new ballast resistor available if you decide to go that way.  You can have it for $5 plus shipping.  I decided not to use it after I bought it.
Jerry (Ohio) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry (Ohio) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 8:30am
If you have a generator put in 12 volt battery, change light blubs and you are ready to go. if you have an alt. you need to put a resistor between battery and coil and you are ready to use.  Don't need to do anything else
David Grubb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Grubb Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 10:30am
This site is one of the best for what you want to do:
http://dueyschutter.freeservers.com/photo3.html
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry (Ohio) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 5:35am
On my post I said if you have an alt you need a resistor in the line from battery to coil. You only need this if you don't have a mag. Generator or alt. makes no difference
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 6:14am
I have always been told that the coil voltage rating needed to be the same as the battery, or if 12v battery use a resistor in line between the battery and 6v coil.  What about it from the electrical guru's??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 11:41am
As John mentioned, we offer a complete 12V conversion kit for the WD/WD45 in kit form with step by step instructions. Gives you eveything needed for wiring along with the correct switches & Voltmeter. We also offer an optional frame rail Alternator mount to position and dial in the Alternator to the engine. Drop us a line or give us a call. Be glad to help you out.  Thank you John for the mention!
Steve@B&B                  B&B Custom Circuits  Newton, NJ
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 12:05pm
Stan, the 6v VS 12v question came up on the "N" Ford tractor board some time ago. Somone did the math to figure out voltage vs. amperage on a coil so the the points would live. I'm sure they came up with a coil primary circuit of 3 to 4 ohms that would keep the amps down to where the points would last. I'd like to say the amps were in the 1-2 range. Can't remember for sure.
MikeB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 10:47am
Steve at B&B:
I'm getting a "not in use" message when I tried to call your shop at 973 632 5596.  Has your number changed?
