WD motor issue,,Opinions please!
LarryWC In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Topic: WD motor issue,,Opinions please!
    Posted: 29 Nov 2009 at 9:09pm
I have #1 cylinder oil fowling out,,#2 is carbon fowled some,,and #3 and 4 are clean as a whistle!
The plugs in 3 and 4 look like brand new.
I'm considering pulling the head and checking the valve guides in and seeing if the valve stems are worn.
It only smokes when it idles for a while, once i throttle it up, it clears up,but then I loose #1 cylinder.
Now, I don't put a lead additive in the gas,and I don't know if it's ever had hardened guides put in it, so I'm thinking that may be a place to start?
What do you gear head AC guys think?
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
www.allischalmersmuseum.com
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 10:14pm
How is the compression?  Could it be the rings?
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 10:47pm
rings or valve guides
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 7:21am
I would take the valve cover off and see if there is any sludge near 1&2 causing the oil to drain down the valve stem. Cal in Ct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 7:24am
OK,,I will check compression and also check the valve stems and see what we have here!
Thanks guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 8:34am
What plug are you using. I used to have trouble with the CA fouling 1 plug after a few hours on new plugs. I put the next hotter plug in and never touched a plug the rest of the mowing season. The CA sat for 10 years before I started using it. The more I used it, the better it ran. The CA had ring problems so if your's is valve guides, hotter plugs might not do as much good.
alan_IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan_IA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 9:18am
sounds like what I had, turned out #1 had a scored cylinder wall.  Cost less to replace motor than rebuild.   I now have a WD45 motor in my WD.  hope your problem is not that bad.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 9:45am
You don't use hardened guides, its hardened seats for the valves with no lead fuel. You aren't working it hard enough to need the hard seats.
When to adjacent cylinders have similar problems its often the head gasket is blown between them, and likely in this case adding an oil passage that's leaking more to #1.
Valve guides tend to leak more with a high manifold vacuum and the highest manifold vacuum is while the engine is coming down in speed from running fast at the time the throttle is closed. So if you goose it, then close the throttle, and get a puff of blue smoke as it gets down to idle speed, that's valve guides, specifically intake valve guides. Seals can do wonders. Guides can do wonders, but then you have to do a complete valve job cutting the seats to be concentric with the new valve guides. And probably break for new valves too.
It could a rocker arm problem where #1 exhaust isn't opening much if at all, but I bet on the head gasket.
Adding a so called lead additive to the gas gets you more rapidly fowled plugs and a thinner wallet, that vendor more profit, does nothing for engine performance or longevity.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 9:58am
Good points Gerald, I'm not as familiar with these engines as others so I appreciate the input on this!
wouldn't the compression test also indicate a possible head gasket issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 10:15am
Gerald covered most things well . might also do a leak down test with compressed air but if oil burning is the problem from guides this will not show up. Fouled plugs can also be from leaks if the plug is burnt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 3:04pm
OK,,,,the verdict is in!
Gerald,,,#1's exhaust valve screw had backed it's self off and was barely opening the valve!
#2 wasn't much better, plus, I had a spark plug that had a small crack along the side of the electrode and was firing down in the plug and not at the point where it should!
after setting the clearance back on the two valves and a new set of plugs,,I'm pullin' wheelies now!!,,,well,,,not really,,but she's runnin' real darn good now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 3:06pm
Oh yeah,,,and I STILL don't know for sure where the oil was coming from,,but I ran her for quite a while and never saw a hint of it!
I'll keep an eye on that though.
