AC Treasures at the Local Junkyard
70Standard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70Standard Quote  Post ReplyReply Direct Link To This Post Topic: AC Treasures at the Local Junkyard
    Posted: 19 Jan 2012 at 8:37pm
Roof Palomino (SN 224), Chetech Pug UTV, Three Green Tractors and one Red Tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:44pm
Well, are you saving them?   I hope at least the snap couplers made it into the back of your truck.   I see at least a set of front rims/hubs/power director, engine internals etc. that might be worth saving on that D14?.   If I had the opportunity, I would buy it for the scrap price, take off anything savable and you can get most of your money back bringing it back once the good stuff is robbed.   still can't believe that some people will take tractors to the scrapyard whole like that.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:46pm
   Some people aint got a clue.
http://www.rumelyallis.com
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:47pm
      I hope that you "purchased" said item.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:55pm
Where did you se a 14 all I saw was a d17
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70Standard Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:59pm
Yes, I did remove the snap couplers and saved them from a trip to China.  The loader was really straight, not a weld or break to be found.  Hard telling what the loader would have brought if sold at an auction.  The wide front looked good too.  The fenders were rotted, and the sheet metal either gone or banged up.  The radiator had been broken out, the water pump broken off, manifold broken, etc.  If I had a need for D17 parts, I would probably still be out there wrenching.  The yard sells outgoing stuff for 30 cents a pound or $600 a ton, so buying the whole thing wouldn't be cheap.
I don't need the snap couplers (my Allis is too old), so if anyone needs them, feel free to contact me.
I also took pictures of a Huber Maintainer sitting about 50 feet away from the D14.  They are posted in the Shops, Varmints... section of this site.
Edited by 70Standard - 19 Jan 2012 at 9:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70Standard Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 9:03pm
I did not.  If anyone is interested in saving the old gal, the yard is Mullins Salvage in Jeisyville, Illinois, (217) 237-4343.  As I mentioned in a related post, outbound stuff sells for 30 cents a pound or $600 a ton.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 9:04pm
I would like that loader. Where in C Il is this yard. PM me if you do not want everyone to know
Sorry 70, I do not type fast enough
Edited by Pat the Plumber CIL - 19 Jan 2012 at 9:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 9:09pm
   There aint nothing like a 300%+ markup, and not doing a damn thing for it !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 9:20pm
I would pay them that much if they would carefully remove the loader and brackets.I just do not want to have to do all that work and then pay them top dollar on top of that. I will call over tomorrow and see if they would come down on price per pound. Maybe as heavy as it is they may budge a little. Anybody know how much a loader,brackets and cylinders would weigh ? 1000 lbs.?
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 9:23pm
$600/ton...A D17 weighs what..4000-4500 fully equipped?? this isn't all there so wouldn't weigh that much. so, at most 1200??  not really all that bad to save a D17 from gettin' crushed!  this really ticks me off!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 9:52pm
Pat that loader wouldnt weigh half of that, I have loaded several of these in my truck by myself, not all together of course but I know it shouldnt weigh 500 lb but cant promise but I know I am not that bad
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 6:23am
You're right, it's a D17, missed the shifter handle looking at it the first time.  Still some good parts on there, the snap couplers being the easiest to remove.
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 6:42am
Ran when parked !!!
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 7:08am
d17 will weigh 6000 easy without loader.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 7:37am
Only with weights and or fluid would a D17 weigh 6,000#. My brother's weighs less than 4,500# with out stripping it and him on it. Used to pull his and my D17. Mine with fluid and no other added weight with me on it weighs just over 5,800#.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 8:25am
Called the salvage yard this morning as I was too busy during the day yesterday. The man who answered the phone said someone from Red Bud Il. had bought the whole thing and was coming up to pick it up. Oh well you snooze you loose. Would have liked to have gotten the loader and front end. Any one on here from Red Bud?
Just glad it is not going to China
Edited by Pat the Plumber CIL - 21 Jan 2012 at 8:35am
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 8:33am
I think we have a member from that area...
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 9:08am
Northside Salvage?
Bigrigger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bigrigger Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 3:08pm
How much are you looking to get out of the snap couplers? Do they work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 5:42pm
Well to top off the scrap stuff, I talked to a guy today who told me he just scrapped a d19 a d17 series 4 and a snap coupler blade with an extension. Day late and a dollar short everytime, dustin     Also he was rather proud of it or atleast that is the way he acted,  kept saying they were junk and hadnt ran for about 8 years,   oh well cant fix stupid I guess
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 5:44pm
Dustin - a crime indeed!  So sad.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
