fixing moulded plastic fuel tank
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Topic: fixing moulded plastic fuel tank
    Posted: 29 Nov 2009 at 8:01pm
Its a jacobsen-so its mostly orange. Fuel tank (diesel) is a moulded plastic of some sort. Has three moulded-in female threaded inserts to take instrument panel. Of course, smart engineering has guaranteed bolt to seize into the inserts. New tank is an arm and a leg. Dug them out (tank is still not pierced)-any ideas of the type of glue (or other technique) to basically refit new inserts in the gouged out holes. Any help or ideas appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 10:07pm
Many of the tanks are polypropylene material and there is only one glue out there but it will only join poly to poly and then I would not trust it to much .
 The only other thing is a weld with poly rod and air torch to direct the heat to base metal and rod to fill in holes , then trying to weld inside a hole is another problem.
 This is all if it is poly, which I think it is.  I did a lot of welding on both poly and PVC and it makes a surprisingly strong weld if done right.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 10:27am
How about a helicoil or threaded insert with the locking fingers you drive down after screwing them in.  Mcmaster Carr has them.
ac crazy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac crazy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 10:58pm
i my self would take it to your local body shop and have epoxy put in it it is strong enough to hold entire body panels on when set it will hold your inserts....our shop guys use it a lot on bumpers and panels...we tested it with two steel plates and two chains pulling on the and you would not believe how much force it takes to separate it... 3m makes it....just fyi
If i can't fix it i won't.
