WC potato steel wheel, Dished type
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Topic: WC potato steel wheel, Dished type
    Posted: 18 Jan 2012 at 4:58pm
This rear steel wheel for 57-1/8" to 83-3/3" tread
A little sand blasting & some paint then they will be going on my unstyled WC. Here's some pitcures to show the offset.
Have a good one. BILLP
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 5:25pm
Gonna look awesome bill! Heard ya got the gov. fixed too!
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 9:37am
Don it runs real nice now. I found in the gov, the pin thst holds the weights was wore real bad causing the problem. I put a new style gov in and a spring from a WD45. I have the sfw frontend all painted up I'll be switching it out soon.
have a good one. BILLP
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 7:57pm
is that a factory wheel?  i didnt know there was such a thing.  are you going to have it spaced narrow or wide?
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:51pm
   Was there a steel wheel for the single front end ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 7:53am
Cal, it will be spaced narrow. Yes this is a type of rear steel was offered on the WC.
Randy, I don't know for sure if a (single) steel wheel was offerd. I did see one at an Auction a few years back I laingsburg Mi, don't know if it was factory or not..
Edited by BILLP-SE-MI - 20 Jan 2012 at 9:34am
This page was generated in 0.254 seconds.
