original ammeter restoration.
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Topic: original ammeter restoration.
    Posted: 16 Jan 2012 at 12:11pm
Has anyone restored and/or repaired the original guages off their tractors?. The guages appear to be in good order other then the oil pressure bezel is cracked and the faces are a little tarnished.  I'm looking for the best method to remove the bezel for cleaning and repair.
1948 WC
Thanks
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 3:41pm
I think you will be looking a long time .Pending on your tractor there lots of better after gauges that look just as the originals did .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 3:53pm
Thanks for the reply.
I'm looking at doing it myself. The meter works.  The intent was to replace all guages but there are minor differences in the aftermarket ones, including the patent pending writing on the original.  If the bezel was more clear I'd leave it alone.  I want the final to be a clean as possible.  I'm trying to salvage as much of the original tractor as possible.
I was curious if anyone has sucsessfully done this and how it turned out.  I won't be fiddling with the meter itself just the face and bezel.
Worst case I can reinstall as the ring was originally orange the discolouration of the glass would be acceptable, but would bug me a bit.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 4:02pm
People rebuild traction-booster gauges, so why can't they rebuild a ampmeter?
Edited by R.W - 16 Jan 2012 at 4:08pm
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 4:15pm
Just saw this on the YT Forum.
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 4:19pm
As Fred mentioned, it would be much cheaper to purchase an aftermarket Ammeter or Oil Pressure Gauge with the AC name on the front than try to restore an original. We have replacement gauges available in stock if interested...
Steve@B&B
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 6:33pm
Not trying to rob anybodys chance for a sale, but a few years ago I had a NOS ammeter that I dropped and broke the glass. I had ATP Instruments in Bloomington, MN repair it and I was impressed with their work, and they are reasonable to boot. In my opinion, the quality of the aftermarket gauges leave a lot to be desired.
Went from this....
to this....
I had them leave the bezel as-is to remind me how careless I was lol!! BTW, the bezel color looks different in the two pics, but it's just the lighting.
I realize that the aftermarket gauges are cheaper, but depends on what you want to do. For a restoration, I wouldn't go any other way. JMHO...
Edited by Chad(WI) - 16 Jan 2012 at 6:39pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:14pm
I'm glad I never threw old gauges. How do you remove the bezel? I might try this some time.
Wink
I am a Russian Bot
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:37pm
I have removed the bezel on both oil pressure gauges and amp meters. I just go under the rear flange and start to bend it away from the gauge and work my way around untilit pops off. Don't try to clean an oil covered white face, the lettering wipes off. Guess how I know. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:50pm
Thanks for all the response
Yes I'm aware of the cost of the replacement being $30 to $40 and probably less for the black face, from this WC.  I've taken on this restoration with my dad.  The WC is his dad's.  The first new Tractor ever purchased by my grandfather for the farm.  Most of the tractor not requiring regular maintenance is original. It's more important to keep as much as possible rather then time.   My time is free.  As a replacement can always be purchased, I'll open the ammeter and give it a shot.
I have the light switch broke down now and removing the rust.  Though that was easier to open
We'll see how the picture post works... if so I'll attach the current photo.
I'm thinking I can rig up a pry with the curve of the ammeter with a tiny hook to lift the crimp on the bezel as it is pushed around the meter...  if I make the hook hard and small enough.
We'll see.  I don't have enough cash to throw at the project for the professional restoration. but that link we be good for future reference
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:52pm
good to know Bob.
I might have to bypass the pressure guage it is black faced but is damaged and there is oil on the face.
I figure it's worth a try
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 7:32am
Started the repair last night.  It is going well, and easier then I thought. The bezel can now be repainted the original colour. the needle I'll repaint as it was white. The glass is in excellent shape. I doubt the face can be fully restored, though with a little carefull attention, I think it will come up well enough, I doubt many will tell unless they examine it pretty close. I've Allready fix the light switch. complete tear down. soaked the parts in a non toxic rust remover and wiped off the rust.
I'm really glad I did this. I'll have about an hours time into the clean up of the ammeter, I'd say still cheaper for me then $30.00 plus shipping and I have the original to put back in.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 2:03pm
How are you crimping the bezel back together?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 6:32pm
The metal is fairly soft and I'll use the flat screw driver to eas it into place then press it with a hardwood press.  I'll drill out the correct size hole and clamp it evenly with c clamps.  I might steal a newer bezel we have laying around if the pits in one side are too hard to even out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 6:33pm
first time posting pics. It will take some time to get the settings right
Edited by Redwood - 18 Jan 2012 at 6:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 6:40pm
here is a couple of the switch more detail needed yet to the exposed knob, and new fuse but ready to go otherwise.
Edited by Redwood - 18 Jan 2012 at 6:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:45pm
For those that are interested I finished the cleaning, and as long a you use a delicate touch this is an easy thing to do. the tear down and repair only took a couple of hours.  The hardest part it the tiny cap that holds the needle down.  It took a couple of tries with tweezer to line it up right to put on.  My only mistake was not putting a piece of paper over the face as I scratched a tiny dot of black paint with the needle putting the cap on.  Once I set up the orange paint I can post the final.
Well worth the time for maintaining some of the original.  I certainly will do the pressure gauges.
and didn't even need to torch ony of these pieces loose.( seat spring bolt won't be so easy)
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 2:29am
nice work redwood, I've done a few gauges ,takes a bit of patience,getting the ring back on neat is the hard part.Keep posting photos.
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 9:48pm
I might give my guuage a rebuild as well.  Inspiring.
Can anything go wrong with the old switches?  I was going to replace mine - But maybe it is ok????  It is a little stiff and need the resister replaced.  Maybe I should?  Is there a way to test it I wonder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 10:37pm
As this is my first attempt and quite frankly was backing up my confidence to the project with the fact that if it did not work I had to buy a new one either way.  The one I opened has only an electomagnet core the flow of electricity through this magnet direction and flow pulls the needle. The best way to test if you have a newer replacement is to swap them out in a circuit they should read the same or if you have an electrical tester to measure amps you could verify the amps that way and compare it to your gauge.  Mine went well.
If you are in the same position I was in, why not open it if your likely to just toss it otherwise.  If it is sticky it might just need cleaning for the needle to float freely.
 I would have saved the face and moved it to a new one if all else failed.
But I only know what I found in mine
This page was generated in 0.043 seconds.
