Gear housing for 220 hy pump?
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Topic: Gear housing for 220 hy pump?
    Posted: 16 Jan 2012 at 7:57am
Pictured below is the original gear plate from my 220 hydraulic pump (left) and a replacment I got from A&I (right) . There is a slight differance in them at the discharge end as you can seee. A&I says no problem works OK or they will take it back. Anyone have experiance with them? Not that much of a job to remove but non returnable once installed.
Edited by Butch(OH) - 16 Jan 2012 at 7:57am
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 11:34am
   We'll sounds like they need to elaborate one or the other ? Will they take it back or not ?
   Is the large hole at the bottom a oil passage ? How's it gonna work without that ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (1) Thanks(1)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 11:46am
Sorry, need to clean up my grammar.
A&I(actualy dealer for them) said they would take it back if I didnt want it but if I install it it is mine. They said they have sold many with no complaints. What appears to be a hole is just a stamp mark in bad light.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 5:05pm
Well, if it doesn't work, a good Partsman or Dealership worth a hoot would take it back as a "defective part" and make their supplier eat it.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 11:16am
Looks like it should work Butch.  The part that does the work is the outside diameter.  It may have a little less capacity than the original.  Ist hard to buy good parts anymore, even the OEMs dont have quailty parts, they just dont care. I know a some instances on a hyd pump if you use the parts from the OEM, the pump will fail!!!
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 12:01pm
I have the same trouble with many aftermarket parts. I try and buy oem parts as often as I can . It is not just one of the aftermarket places it is all of them. There specifacations are off on most parts ,some work somework with modifacations and some don't work at all. Being in business I can't afford to work with junk and get machines back because of poor quality parts. Just my 2 cents.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 9:21pm
Bet a nickle that new wear plates and backup rubbers would make a world of difference using the old guts. Mine had been run leaking by so long that it eroded one of the grooves in the aluminum hsg and wouldn't hold new backup rubber. Just a nickle mind ya.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 9:40pm
I dont remember a difference like that, but I know on our XT series 3, I replaced the stock housing that had cracked with an A&I, and it worked just fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 7:21am
A little history on it. A previous genious type had removed and by-passed the hyraulic filter unit from the tractor. First thing we did was source and install the filter and change the fluids. We knew that wouldn't fix the pump but seemed like a logical first step. We then got into the pump and the usual wear parts you mentioned were trash plus the gears them selves which were BIG bucks and only available through AGCO.   We could see the housing was worn but the price quoted from AGCO was more on the order of  insane than simply over priced so we installed the new gears and wear plates and hoped for the best. This improved it but we still are not where we need to be.  My tractor has no 3 point but does have PTO which is a pump and sytem all to it's own as far as I can tell from my manuals? Differant from 3 point tractors and differant from flatbacks.
Edited by Butch(OH) - 18 Jan 2012 at 7:23am
This page was generated in 0.207 seconds.
