NUTS!!
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: NUTS!!
    Posted: 16 Jan 2012 at 7:37am
So I get some fine threaded nuts for some bolt/pin on the all-crop...but they dont work on the bolt!..refer to the hardware reference book (worth is weight in gold) and turns out AC had used a "looser" fine thread and a "tighter" fine thread...WTF!! talk about over-engineering!  Well its seems my bolt uses a "looser" fine thread, and the off the shelf fine thread is not of that type. Part 910124...hoping SLI can get me some.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 8:14am
That's a new one on me!
Gary in da UP View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 8:15am
Seems like there's a course pitch, fine pitch and son of a pitch, eh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 8:19am
Yeah kinda peed me off...SLI got back with me...hope to get the right nut...I guess it has been superseded twice..the second supersede sounds suspciously like an ordinary nut... I ordered the first supereded number and will hold my breath...come to think I will order the other part just in case as well...
Did a google on the subject and did come across some verbiage regarding degrees of "fineness" so to speak.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:36am
yeah...well wait til ya get some backwards threaded nuts!! pffft
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:36am
where are those nuts used? There should be some out in the pasture, on those parts 60 and 66.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:43am
They are used on the pins that attach the straw rack and pitmans to the rockers.
Standby I may need them if what i ordered doesnt fit...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:53am
Yazzie,  Are ya sure they didn't get superseded to Metric? The way things are farmed out and made today in foreign countries, ya never know!!  LOL!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:58am
Steve@B&B
If so, then the company that did it (not sure if Allis or AGCO) deserves to go out of business for such idiocy as to list the wrong type of nut.  The first supersede says "American Fine", second supersed says "Standard National fine" - well never heard of "American Fine, but it sure aint "Standard"!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:02am
Ah yes the % of thread in holes I have found but not the difference in nuts.
Then being around British Motorcycles and finding Witworth, British Standard, and a few other thread sizes , then throw in Metric and US thread pitches both on my 76 Norton along with BS makes it a fun experience in repair
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:26am
Yes I know about the % of thread deal but I dont believe that has anything to do with Tom's problem. When performed corretly any % thread will screw into or over any other % thread because the beginning hole or shaft size is varied to suit. As an aside most commen tap drill charts are 60%
Edited by Butch(OH) - 16 Jan 2012 at 10:27am
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:28am
Yes Tom, there are difference tolerance on threads. (See below)
"Thread Classes: The different thread classes have differing amounts of tolerance and allowance. Classes 1A, 2A, 3A apply to external threads; Classes 1B, 2B, 3B apply to internal threads. See Unified Standard Series."  I'm not an expert, but being an engineer, I've run into this in the past.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:31am
So what class pertains to NF "standard" fine threads?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:39am
NF stands for "National Fine"
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:39am
I went to the cheap Chinese tool store and bought a Tap and Die set to use for cleaning up threads on stuff I took apart. Most of the time it works just "fine", but for some reason, the threads on the hand brake levers off the B's are really tight in the die. I had always chalked it up to typical quality from that particular tool supplier. Maybe I unfairly blamed them?
Could it have been an Allis enginer? Perish the thought!
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:40am
What size is this particular size you have in question?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:42am
Yes I know, thats not my question.  The dealer states a "standard" NF...What would be "standard"; Class 1B, 2B, or 3B?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:43am
5/8"...
when I put what I assume is the "standard" NF nut from the hardware store, it goes only so far then binds up.
Edited by TomYaz - 16 Jan 2012 at 10:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:43am
Tom, Whatever the threads are, measure the OD of the bolt and count the number of threads in an inch and you will know what to order. 1/2-13 is a half inch diameter and 13 threads per inch, 1/2-20 is half inch with 20 threads per inch. If you have the bolt, you should be able to order nuts by using the size and pitch to match.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:47am
I already placed an order with SLI, hopefully that will do the trick.
BTW I got the last 5 known pins of a particular type, will use the last one as a template to make new ones....WITH "STANDARD" FINE THREAD!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 10:58am
5/8-18 or 5/8-24?
2B would be considered "standard"
here are the measurements from the ANSI/ASME B1.2-1983 book
5/8-18 2B UNF
major diameter 0.6250"
minor diameter 0.5889"
5/8-18 3B UNF
Major Diameter 0.6250"
minor diameter 0.6175"
5/8-24 2B UNEF
Minor Diameter 0.5979"
5/8-24 3B UNEF
minor Diameter 0.5979"
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 11:24am
Here is info on 5/8 threads.  You may need to check the thread pitch as there are other pitches 5/8-12 and 5/8-20.
External Thread /Internal Thread
 Nominal Size, TPI, SeriesClassAllowanceMaxaMajor
Max Minor
Min Major
Min Minor
Min bMaxaPitchMin PitchUNRcMinor Dia
Major Dia(Min)
Ext.5/8-11 UNC1A0.00160.62340.6052-0.56440.55610.5152
Int. 1B 0.54600.5270 0.57670.56600.6250
Ext.5/8-11 UNC2A0.00160.62340.61130.60520.56440.55890.5152
Int. 2B 0.54600.5270 0.57320.56600.6250
Ext.5/8-11 UNC3A0.00000.62500.6129-0.56600.56190.5168
Int. 3B 0.53910.5270 0.57140.56600.6250
Ext.5/8-18 UNF1A0.00140.62360.6105-0.58750.58050.5575
Int. 1B 0.57800.5650 0.59800.58890.6250
Ext.5/8-18 UNF2A0.00140.62360.6149-0.58750.58280.5575
Int. 2B 0.57800.5650 0.59490.58890.6250
Ext.5/8-18 UNF3A0.00000.62500.6163-0.58890.58540.5589
Int. 3B 0.57300.5650 0.59340.58890.6250
Edited by ALinIL - 16 Jan 2012 at 11:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 11:43am
5/8-18 or 5/8-24?
5/8-18 2B UNF
5/8-18 3B UNF
5/8-24 2B UNEF
5/8-24 3B UNEF
Matt, Al;
Good stuff; thanks...now if someone could explain to me why AC would go with a "looser" fine thread for these pins....some engineer deciding to get a giggle out of someone like me?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 12:47pm
Tom - Because of where these are used ie; lots of vibration, they may have used a
class 3 with no lock washer and a thread sealer to prevent loosening.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 1:02pm
nah. Calls for a lock washer..and wouldnt you want a tighter thread as opposed to a looser thread this has for that situation? (I dunno, Im no expert) Did they even have thread sealers in the 1940's?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 1:18pm
Oh well, like you, don't have a clue.  At this point, I'd replace with 2A,2B.  Also they did have thread sealer in the 40's.  It may be possible you are dealing with someone else doing a repair before you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 1:25pm
Cant really replace. The pin with these goofy threads is proprietary. I have NOS of this pin and its the same way. Hardware reference from AC calls for "NF-1" for this particular bolt. It also lists a NF-2 and NF-3 as  possible sizes - and thats seems in step  with  your  1A,2A,3A sizes.
Edited by TomYaz - 16 Jan 2012 at 1:26pm
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 8:17pm
Different but somewhat the same.
NPT- National Pipe Thread, right? wrong. National Pipe Taper.  There is a National Pipe Straight  NPS
NPS seems to be used for higher pressure. It uses a copper washer, much like a garden hose gasket/washer.
I also learned that a 3/8" NPS-18 is the same diameter as a 5/8-18 bolt but a die for it will not screw on  3/8-18 NPS. Not sure but it appears the thread pitch is a little different.
Dusty
Edited by Dusty MI - 16 Jan 2012 at 8:21pm
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 1:15am
I would just buy a thread file and hit the bolt a few times. Or get a tap and run it in and out of the nut a few times.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 6:43am
 I saw this topic I thought you were posting about me because I'm Nuts!!!
Wink
I am a Russian Bot
This page was generated in 0.057 seconds.
