WD Weights
DOlson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DOlson Quote  Post ReplyReply Direct Link To This Post Topic: WD Weights
    Posted: 16 Jan 2012 at 7:01am
How long do the bolts need to be to hang two weight sets on a WD. I want to buy the right bolts.
Thank you,
Derrick
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 7:45am
i use 4in. with flat washer and lock washer. 4 x 3/4 carage
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 8:13am
If your going to hang two weights on each side you will need 4 of the 3/4"X4" carriage bolts per side, so 8 total. Use 2 per weight and don't forget to put the bolts through the first weight before you put it on the rim, or you will have to take it back off. Don't ask how I know this... Not a good close up picture, but here is two weights on my early 17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DOlson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 8:09am
Thanks for the reply's just wanted to order the correct bolts
This page was generated in 0.307 seconds.
