WD enginge in a WC
chickenmann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Topic: WD enginge in a WC
    Posted: 15 Jan 2012 at 1:56pm
Is it a direct swap to put a WD engine in a Styled WC or is there a conversion that must be done?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 8:41pm
Pretty much, unless there needs to be a hole in the hood for a muffler.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 11:03pm
Yep, there's a WC sitting in a fencerow nearby with a WD engine. Without actually having done the swap, it looked like it basically bolted right up.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 7:48am
201 engines in a WC and WD are identical. Bolts right up. A 226 from a WD45 bolts up just the same too. Like Dr. Allis said, unless you have to add a hole for the exhaust. WC manifolds were side exit and WD 's came out the top.....the manifolds are interchangeable too.
Edited by BennyLumpkin - 16 Jan 2012 at 10:02am
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 1:43pm
Side exhaust were normally found only on Distillate engines.  Not Gasoline models.
This page was generated in 0.048 seconds.
