Am I missing something here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Am I missing something here?
    Posted: 15 Jan 2012 at 12:12pm
Took off the wide front off the D19 to fix the front main seal, look at the steering box, and to put the narrow front on when I am done.   After getting the wide front on and taking a look underneath, I only have four holes to pick up the narrow front, but the narrow front has five holes to bolt up.   Am I missing something, or does all D19's only have four holes, or did I find something where someone in West Allis in the 60's had too many beers playing sheepshead the night before and only got four holes drilled and forgot about the last one.   I will take some pictures and post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 12:30pm
Here are some pictures.   Top of the narrow front showing the five holes.
Here is a picture of the bottom of the steering box.   As you can see in the pictures, there is one hole at 12 o'clock, one at 3, one at 5, and one at 7, but the one at 9 o'clock is not there.   I thought it might have been gummed up with grease so I scraped it over really good with a screwdriver and no hole.
If it was something that was missed, I am taking the steering box off anyways to deal with the front seal etc. so I can flip it over and mount the narrow front and locate where the hole is supposed to be and drill and tap it.   Should be able to copy the depth of the other four holes so that I don't drill too deep.   Just making sure that I'm not missing something or that for some reason, they didn't drill and tap this hole at the factory for some specific reason.
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 12:56pm
They are there I see all five I think, but are full of crud. Mine had all 5 as I put the narrow on last weekend. I may get it out and take some more pictures today.
The yellow circles are where the WFE were and need 5/8" bolts put back in. The red circles are where the narrow front will go once you find and clean out the holes.
Edited by Travis(NE) - 15 Jan 2012 at 1:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 1:00pm
Sorry I missed the part where you scraped around the 9 o'clock and no hole... :-(
If you just want shed space and room to work and are not going to farm with it I would think 4bolts would hold it fine until you get the WFE back on or a different bottom for the steering block.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 1:02pm
   Is there a bolt sheared off in the 9 o'clock hole ?
http://www.rumelyallis.com
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 2:15pm
Hmmm... looks like it originally came as a WFE, so I kinda doubt anyone sheared off a bolt...
either way... this sucks!  Nothing worse than drilling and tapping an overhead hole...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 6:19pm
Mine is a real early one and had all 5 holes.
Maybe yours is a later one and to save money they didn't drill and tap that one, or like you said somebody was having a rough morning as a side effect from a really good night? LOL
I would think you could find that bottom piece of the steering support from a doner 17 or 19 easier than drilling and tapping that one. I know i have one or two in the parts pile somewhere and can't drill a straight hole to save my butt and if I did get a good hole the tap would just break off anyways...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 7:04pm
Well, I do have the whole bolster removed anyways to deal with the front main seal, I have one of those center punch sets so I will mount it and center punch the one hole and then hopefully I can get it set up on my drill press without the hole thing falling over and get it drilled and tapped out.   If I get it set up on the drill press right, I can use the table to set up the depth and check the other holes so I don't drill in too far.    Just another thing to add to the list.   Looks like the wife will lose her parking spot for a couple more days!!
Edited by ChuckLuedtkeSEWI - 15 Jan 2012 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 9:24pm
Well, tore into it some more tonite and there is a hole there, and a broken off stud.  Randy, you were right.   So hopefully I can drill, ez out and retap the hole.   When I took it off though to put just that piece and not the entire steering box up on the drill press, the back casting of another hole had been broken off and a bolt with some teflon tape was run into it from the back side.   So there must have been a narrow front on here at one time, and possibly a bolt or two got loose and this and one broke off, and the other busted out the backside.   So I can probably clean the one hole out and retap.   The other, I was thinking about putting a nut on the inside side, using a bolt to line up the thread with the threads in the main piece, welding the nut on, and then welding the end of the nut closed to seal the hole so that it doesn't leak out any fluid.   Or am I better off finding another piece like this from another front steering box, that someone might be willing to part with.   Here are some pictures, you guys be the judge.
Edited by ChuckLuedtkeSEWI - 15 Jan 2012 at 9:31pm
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 9:50pm
Very interesting Chuck.
 I would say that it definitely had a narrow front at one time. Must have been some pretty rough terrain it was used on. Looks like they decided to change to a wide front after several repairs had been made to the NFE. I would check the other holes for wear by screwing a bolt into them and checking to see if you can shake them any. If so, you may want to consider a "new" piece. Threads could be wallowed out in all of them, making your new NFE unsafe. Helicoils could be an option here, depending on what you plan to do with the tractor. I don't think I would trust them to hold it if you were going to be using the tractor for field or chore work.
You seem to have a fairly well equipped shop. Rockmount makes a very good cast rod called a Jupiter 888. It would do a sufficient job of closing the damaged holes and allowing you to redrill and retap them to the correct size, if you can't find a donor piece. To do this properly, you would probably want to weld all of the worn holes shut(after a good cleaning) and redrill them all. Follow the directions for the rod to the letter(you can get them online from Rockmount if they don't come with the rods). I believe they call for a preheat of the entire piece, followed by a controlled cooling(maybe in a sand pit) before the piece will be ready for any machinework, but it isn't as hard as it seems. Doesn't take a lot of specialty tools, and sand bags can be bought at your local Home Depot.
I think you can fix it. If it were mine, that's what I would do, but I like to do things the hard way. : )
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 3:15am
I've seen something like that happen on a 17 only on a hole for the WFE support, but whoever did it drilled and tapped the hole for a 3/4" bolt. Found out when I went to take the bolt out and the normal 15/16 socket wouldn't work and had to use 1 1/8 and then when the bolt came out so did the oil! Was not expecting that. Anyways at this point I feel you would be better off finding a replacement piece. If you can't find one local let me know and I'm sure I have one someplace and could help you out.
Not to change subjects, but what did you find out with your Hyd line and diverter valve? Also did yours have the front pump on it when you got it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 6:11am
The front pump was taken off when I got it.   As far as the diverter valve, I still have the valve if you want it.   If you have the piece I need I would be happy to trade up even for them.    I don't have the line that went up to the front anymore though.   If I remember right it was cut.   I might have both the pieces though, I will look tonite.  Just the diverter valve and the mounting bracket.   I am most likely gonna do pulling with this tractor, so I would like to make sure the narrow front is up to snuff, especially with the fact that you end up with the front end in the air at times and then it can come down hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 8:16am
Sounds like a plan Chuck! I will look for the piece you need when I get home and post a picture.
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 12:41pm
If done right helicoils are as strong as orginal in steel and cast and stronger in aluminum. now that said you have to follow their directions exactly the right size drill bit and make sure that when you tap the new hole you are good and square.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 1:30pm
Parts have been found!
I almost messed up and brought in a front off of an early 17(it was easier to find) but noticed it has the smaller outside holes for 1/2" bolts. This one is off of a 19 and as soon as the front warms up(it was outside and is in the teens today) I will take it apart, clean it up, and give it a good look over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 2:27pm
Way to go Travis!
Does it need transport from you to Chuck?  IF so, shoot me a PM... I have an idea...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 2:32pm
Yes it will. My plan was to take the piece off that he needs and FedEx it to him. I am open to options and if Chuck could use the whole thing and you have ideas I'm sure we could work something out. I am in the Seward/Lincoln area, but would be willing to travel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 4:04pm
Chuck the part cleaned up nice and looks good...
The bearing race and seal looked not so good, so I removed them to clean up behind them...
The seal has C/R 262FM124 on it and the bearing race says Bower 12303. You can have all three pieces at no extra charge if you like. LOL
Then I found these in my toolbox dated 4/5/04...
They were from a deal I thought I had trading parts for a SFW that fell through
Seal is AGCO # 70229966 with funny markings on the rubber F3117 TB2 262 175 50 TTO?
O-Ring is AGCO # 70236753
Obviously I haven't needed them yet, but may someday... If you need them also let me know
Edited by Travis(NE) - 17 Jan 2012 at 4:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 5:10pm
Thanks Travis.   I went to the local bearing house and got new orings for the steering control valve and while I was there, I did get a new big oring like that and I got a new seal for the middle.   Actually they didn't have an exact match with a felt and rubber seal in one, so I got two thinner rubber type seals and was gonna put them in back to back.  I figured with how little that turns and the fact that the narrow front will keep dirt/grime getting at the seal it will be good enough for my lifetime.   I will take a picture of the valve I have and hunt down the metal tube.   I dont' know if you need that or not, but if you do, and it's repairable, you can be the judge.   I have to leave now, but I will take some pictures after dinner for you and get things on my end.   Thanks a ton.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 5:58pm
No hurry on the valve or line Chuck your word is good enough for me and I will not be doing anything with them any time soon. If that piece is all you need from me PM me your address and I will get it on the way unless I/we hear DaveKamp's idea before that...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 8:09pm
Travis, I got everything all cleaned up and some pictures taken.   I sent you an email to the email address in your profile.   If you have slow loading, let me know and I can post the pictures on here.    Thanks again for the help.   I also included my phone number if you want to call.  Or send me your phone number and I will call you on my dime.
thanks,
Chuck
allis chalmer d14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis chalmer d14 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 8:30pm
use 4 grade 8 bolts and make sure their tight that all you need and go back to running it
allis chalmers d14
