WD how to remove bevel gear?
maurice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maurice Quote  Post ReplyReply Direct Link To This Post Topic: WD how to remove bevel gear?
    Posted: 14 Jan 2012 at 7:54pm
How does this bevel gear come off?  I have the snap ring off (picture taken before), and have tried to pry on it.  I assume there is a key between the shaft and gear.  (This is side belt drive).  Is a special tool required?  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 8:00pm
Small arbor press might do it. If you don't have a way to press it off, maybe set it upright and heat the gear around the outside. It will probably fall off. ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 10:09pm
Take the shaft out and press it off.  MACK
This page was generated in 0.069 seconds.
