Harvesting corn with the L2 in 2011
 Rating: Topic Rating: 2 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: Harvesting corn with the L2 in 2011
    Posted: 13 Jan 2012 at 9:50pm
I forgot these pics were taken. Corn in this field averaged 193 Bu/Acre. 42 acre field only but my largest.
Wink
I am a Russian Bot
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 8:17am
Nice loking combine. We sure had a beautiful fall season here in Minnesota in 2011 didn't we? Couldn't ask for better harvesting weather.
Edited by AllisFreak MN - 14 Jan 2012 at 8:20am
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 8:25am
You can tell from the pics that machines been well taken care of. Good looking L2. Corn yield not bad either.
schwanman66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote schwanman66 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 9:02am
That is a good looking L2!  It brings back memories!  Did you add the 2nd fuel tank to the combine?  Wasn't sure if that was a factory option or not.  We added one to our L3 When we had it back in 2000 to keep us moving on.
1970 & 1971 190xt Series III's & 160
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 9:14am
Thanks guys. My manual shows a 2nd tank available as an option and that exactly doubles the capacity. The 2nd tank was on when I got the machine and it looks like a tank off an M that someone else put on later.
Wink
I am a Russian Bot
RPSallispullinmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RPSallispullinmd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 9:23am
Lonn, nice looking L2,as you can see from my post I have an 82 M2 630's picking corn this fall to here in MD.Gotta love these old Gleaners still doing there thing.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 9:33am
I had a 79' M2 variable speed but never got to use it. I sold it to the neighbor and bought this L2. My neighbor really likes the M2. He never ran a Gleaner before. It's a miser on fuel and so simple he tells me. I already knew that!
Wink
I am a Russian Bot
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 9:36am
I have a 2nd tank on my L3 also. It was on an M2 when I bought that and then transferred to L2 and L3. Can go at least 2 full days without refueling. Only problem I have is they don't empty at same time. Have to shut one off and then just use one at a time. rrhead(SD)
John D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John D Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 11:51am
Looks real nice - we had a M3 gear drive and loved it.
1964 D17 series 3
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 7:51am
If there is a drain in the bottom of each tank you can connet a line between them and then it will maintain the same level in both of them the bigger the line the faster it will level out. One tip put a valve at both tanks incase you need to shut one tank off.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 9:07am
Thanks for the suggestion. I understand what you are talking about. I will try that next summer before we do oats. rrhead(SD)
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 11:53am
I've considered adding a 2nd tank to my L3.  How was the factory installation done?  Shutoffs on each tank and only use one at a time?
I've wondered how you have two tanks plumbed together and don't run one over when on steep hills unless you have shutoffs on each.  Also, if you have the return line going to the front tank, but are using out of the rear, will that be a problem? i.e., over-fill the front tank or empty the rear tank too quickly?  I guess I don't know how many gallons per hour the return line transfers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 1:06pm
I'm use to two tanks plumb together on trucks, but they only return to one tank and don't run over. And about running over on hills as long your moving it will not have time to transfer before over fill the other tank. And like I said the larger the hose the faster the transfer. Keep the hose around 3/8" to 1/2" and it should be enough to transfer fuel but not run fuel over on hills.
1969 190XT series 3
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 7:13pm
Nice pics   Lonn
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 7:56pm
Very nice combine Lonn!!! It has been very well taken care of by the photos. Are you the original owner? How many hours are on it? Ryan
Kurt WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 8:11pm
Great photos, hope she works as good as she looks
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2012 at 10:02pm
I was only 12 when this one was built. I bought it from Chris Strong down in Iowa. Not sure how long he had it but he must of taken very good care of it and he put some dollars innew parts into it. It has about 2800 hrs on it. The machine really can take corn. Right after I bought it the injector pump went bad and this year the cleaning shoe bushings went bad and shook the shoe up some so I patched it up to finish the season but I believe I will take the shoe out and put some new panels and shoe bottom in. I think the bushings, which were replaced just before I bought it, were put in wrong and that was the cause.
Edited by Lonn - 15 Jan 2012 at 10:03pm
Wink
I am a Russian Bot
