226 combine engine into a wd45 |
Post Reply ![]() |
farmer_rob ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: N.Lancaster ont Points: 362 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Jan 2012 at 8:07pm |
i can get a complete 226 out of a combine but i was wondering what all i need and or change to get it to run.. i know ill need the gov off the tractor plus the bell housing.. anything esle needed or missed
if farming was easy everybody would be doing it
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
change gov. setup--wAter pump--carb linkage-throttle shaft or put the one from tractor---done many 1-574-342-4545
BennyLumpkin ![]() Orange Level ![]() ![]() Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
The whole front plate is what I understand needs changed over. The bellhousing isn't different. 201's and 226's all have the same bolt pattern. Pretty straight forward swap.
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
Carl(NWWI) ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: NW WI Points: 954 |
You will have to grind some off the frame rail for the governor casting on the block. Be the right side of the block, it'll hit the frame, grind like a 1/8-1/4 off and as wide as the casting.
Carl |
Post Reply ![]() |
