Oil filter failure
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Topic: Oil filter failure
    Posted: 13 Jan 2012 at 4:10pm
My new D-14 showed good oil pressure on the gauge and I guess it had plenty.
Anybody know what caused this or how to correct it I don't want to do this to many times, because filters aren't cheap.
Thanks for any help or opinions.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 4:21pm
Maybe your relief valve is frozen??? Was it a new filter, maybe it was defective??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 4:32pm
It wasn't brand new, but I don't know how old because I just got the tractor. It will peg the gauge when first started but comes down to the middle or slightly higher once it is warm.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 4:39pm
Boy, never seen that. Almost looks like it froze somehow?
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 4:55pm
The relief valve somewhere is stuck. There is one in  the oil pump and another at the front of the camshaft. When I bought my ol14 the oil gauge was rusty so I stuck one on from a car that read 80 psi. When it warmed up it wouldn't show any pressure so I put a washer behind the spring in the oil pump and I had great pressure but when the weather started getting cooler it would do the filters just like that. I took out the washer and got a gauge made for low pressure and it was fine. That was thirty years ago. I doubt anything was wrong with the filter. Wix is a high quality filter even though for some reason a few years ago they changed the design on the AC filter for awhile and it gave them a bad name. The one you have is the good one and I have never had a problem with them and I use mine to feed hay every other day in winter. Hope this helps.JP
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 5:13pm
I would be putting a test guage on it that shows pressure in #s  and see exactly what it has. But it sounds like you have an oil pressure relief valve problem. As most only run half way on guage. a little more cold/  Our old D-14 engine is low on oil pressure gauge never goes over half cold.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 5:21pm
I would screw it off and look for ice/water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 5:30pm
I didn't see any water or ice and there was no unscrewing it. It blew right off the base.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 6:42pm
I have heard of that happing a few times. Faulty oil filter or a plugged up filter that had a bad relief valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 6:52pm
I think I'm going to change the oil to 5-30 and swap a filter off one of my WD's on it in case it blows that out too and see what she does in the morning. Is the pressure relief accesable from the outside like the 201 and 226 engines?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 7:07pm
I could be wrong, but I think the oil filter should have been of the cotton nature, and that is what is supposed to build up a little resistance and give you oil pressure. I know it sounds strange, but there was much discussion on the topic a few years ago and I believe it pertained to D14's and 17's. Maybe someone that knows more will chime in. Only thing that don't add up though, is that a faulty oil filter would cause a lack of oil pressure. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 9:41pm
Have saw this happen on a D15. Ball in front of cam shaft was stuck.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 10:12pm
But, a D14 should be the "bypass" oil filtering system with the standpipe up thru the center ( like a WD45)......is the hole from the filter base to the block plugged  so oil can't get out???
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 10:15pm
You have to take the radiator off to get at the pressure relief valve. There is a square plate, on the timing cover, that must be removed, very carefully, and a spring and ball are behind the thrust plunger. My plunger was rusted really bad and I replaced it when I overhauled the engine.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 7:32am
Didn't you say you just bought it? I wouldn't do anything to it until I changed the oil and put on a new filter. If you don't know what it has in it then it could have maybe 50 weight racing oil or something in it to keep good pressure. This works good as long as you drain it before winter. I ran mine for about 25 years til I finally done a complete rebuild on it. I used to use the heavy racing oil and it would hold pretty good pressure all summer but you had to get it out before cold weather. I used to have a car I did the same thing with but like I say it had to come out for the winter.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 7:37am
Darrell, I don't know why that material looks like that but they do have the cotton in them. I use the Wix 57011 and it is the proper filter for the D14 and others.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 8:23am
I think I am going to swap change the oil out and try some 5w30 and see what that does for pressure.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 10:09am
I'd also make sure it's above freezing when you start it up..............just to be safe.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 1:06pm
New 5w30 oil had no effect. I stuck on a old filter to see what happened and it started to swell up so I shut her down. I guess I need to start looking into what is causing this. I noticed that there is oil in the base where the filter mounts and it drains away slowly, but it doesn't seem to be restricted. I see a small plate on the timing cover with four nuts retaining it, is this the plate that holds the pressure relief valve? it seems that it would be accessible without removing the radiator, can I just pop the plate off and check to see if there are any shims and remove the ball and spring to check them over or is it possible to loose pieces in to the engine this way?
Thanks for all the help so far,
Denis
Gerald J. View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 3:13pm
Is the bypass filter on the drain side of the pressure relief valve? Then it should drain to the crankcase and never see much pressure. Isn't that why the paper filter failed, it let too much oil flow freely so the regulator didn't hold oil pressure? If that's the case then that drain line is plugged, probably with chunks of the previous filter filling.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2012 at 6:14pm
The filter puts back pressure on the system. That is why the "new design" Wix came out with a few years ago didn't work right. I still don't why they did that. The oil pump has a relief in it and the cam does too but I can't think how it all works. I do know when I shimmed the valve in my oil pump it swelled the filters up.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 5:11pm
Ok, so I put a magnetic heater on the oil pan and left it until the oil was good and hot then I tried to fire it up. It started up fine and made the gauge go about 3/4 of the way to maxing out. This was ok because it didn't affect the filter. So I drove it in the shop to investigate. My plan is to pull the radiator out and check the relief valve. Is there anything else I should check while its apart?
Denis
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 5:57pm
Denis.  Check  for  correct  thickness plate end of cam.  Albert had  this  problem last  summer , i sent  correct  thickness plate  , problem solved.  No more  ruined  filters .     Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 6:10pm
So I pulled it apart and found out that the "Thrust Plate" as it is called in my shop manual, is missing, it is the piece that goes between the "Thrust Plunger" and the Cover. From what I can figure I should have the opposite of my problem with that piece missing. So I am a bit confused at the moment.
Any ideas?
Thanks,
Denis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 8:53am
Can any body shed some light on how the D14 oil system works? I was under the impression that it is a bypass filtration system, but I only see one line coming out of the pump then it goes into the filter base. I don't see any other outlet for oil to come out of the pump?
Thanks,
Denis
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 9:10am
Oil pump is located at rear end of cam. and I believe most of the oil is pumped through a passageway inside cam.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 1:02pm
Thanks,
Denis
One line goes to the filter base and is fed through the filter and teed to the pressure gauge. Back pressure on the filter limits how much oil goes through it. What doesn't go through the filter gets pumped through the engine internally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 2:28pm
So does oil come out of the pump in two places or just the one line that I can see, I assume that the filter base is made just like the ones on the B,C,WC,WD,WD45 and just dumps back to the crankcase?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 5:53pm
OK, So I most certainly have a oil pressure issue. I installed a gauge that has numbers and I have well over 100 PSI at the oil filter base and the port on the side of the block. I am using 5w30 oil and the temperature outside is about 24. The relief valve is unseating because it is leaking oil out of its cover, so I don't really know where to turn from here.
Any ideas?
Denis
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 6:49pm
Remove the base and make absitively sure the hole into the block is open and can easily let air blow thru it and the base is free flowing as well to the block.
