Converting G back to 6v positive ground
Kevin_49G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin_49G Quote  Post ReplyReply Direct Link To This Post Topic: Converting G back to 6v positive ground
    Posted: 12 Jan 2012 at 10:37pm
Looking to convert 1949 G back to 6v positive ground. My grandfather bought this G new in 49. I have the 6v generator which likely needs rebuilt. What other parts will I need? Heres a list of ones I think I need.
6v coil
3 position light switch that controls charging rate
New wiring harness
6v battery
6v ammeter 30-30
Starter?
Any comments would be appreciated.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 10:43pm
   If your generator needs rebuilt, why not just convert it to a 12 volt ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 10:45pm
Amp meter doesn't care abut voltage only measures amps. you will need a 6 volt cutout relay or voltage regulator, starter if it works now will work on 6V or 12V,
 If generator is good 12V now keep it , if you have to rebuild one it's the same for 6 or 12V but finding the 6 volt reg might be harder .
 See if Steve at B&B who has adds on her has the wiring harness or the other things you need .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin_49G Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 10:56pm
It has been modified to 12v with an alternator, was hoping to restore to original 6v setup. Plan to completely restore if I can find all the parts I need. Just got it started tonight. Hasnt been run in several years.
Thanks for the info on the cutout relay and that my starter should work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 11:17pm
We can help you out with everything electrical needed for your Model G. Also can rebuild your Gennie, Starter, can supply you with a cutout, new wiring system, and even a new dash if needed. Drop us a line or give a call. Be happy to help you out with anything you need....
Steve@B&B         973-632-5596
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin_49G Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 11:20pm
Thanks Steve, will be calling you.
