D17 Points
Dean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean Quote  Post ReplyReply Direct Link To This Post Topic: D17 Points
    Posted: 28 Nov 2009 at 7:35pm
 I have a 1958 D17 that seems to burn-up points.  I have 12 volts at the distributor when the tractor is running, this seems odd to me.  Should there be a restrictor in-line or in the coil to knock it down to 9 or 10 volts?  I know my dad replaced the coil from an  automotive store.  Any help is appreciated.  Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 8:03pm
If memory serves me correctly, you need a coil with 3-4 ohms resistance for 12V. You might look on the coil and see if it says to use a ballast resistor. For many years I used a 12V coil on my CA that was from a Kohler engine with battery ignition. The Kohler coil had the ballast resistor built in.
When you measure the primary voltage you will see battery voltage at the coil and should see about 6 to 8 volts on the dist side with the points closed.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 8:05pm
I would say if you have a 12v system with a 12v coil, you should have 12 volts at the coil. If you have a 12v system with a 6v coil, the coil will usually heat up and cause missing before it dies.  Is the coil grounded the same as the battery? If you have a positive ground set up the + side of the coil should go to the distributor. If you have a negative ground, the neg side of the coil should go to the distributor.
Edited by CTuckerNWIL - 28 Nov 2009 at 8:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 10:15pm
When running a 12V system with a 4 cylinder engine, you need 2.7-3.3 ohms of resistance in the Ignition circuit for the engine to run correctly and not burn up points. You can go to the local Auto Parts store and pick yourself up a 3.0 ohm coil. Make sure it has a built in resistor. That will put you smack in the middle of the ballpark. Renew the points, and you should be good to go. If you have a problem locating a coil, we have plenty of em' in stock..... HTH
Steve@B&B
Dean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 8:23pm
Thanks Steve, that helps a lot!
