Transmission oil TL-10
satbep View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote satbep Quote  Post ReplyReply Direct Link To This Post Topic: Transmission oil TL-10
    Posted: 10 Jan 2012 at 4:11am
Hi all,
I have an old TL-10 and i would like to know
what kind of transmission oil i need to use, i want to restorate
this nice old machine, starting withe tre clutch and transmission.
Thanks for your help....
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2012 at 12:01pm
As per the TL-10 TRACTOMOTIVE PARTS and INSTRUCTION book I have. 1000 hour service for transmission, Capacity 19 quarts. Drain and refill. Drain plug located on the bottom of transmission. Refill to upper petcock level. For temperatures above 20 deg.F use SAE 20 oil. For temps 20 deg.F to 0 deg.F use SAE 20 oil (diluted with 25% kerosene) and for temps below 0 deg. use 5W-20 or SAE 20 diluted 50% with kerosene. That's as printed in the original 1957 manual. I'm sure there are some other options.
This page was generated in 1.039 seconds.
