Need shank for spring-tooth harrow
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Topic: Need shank for spring-tooth harrow
    Posted: 09 Jan 2012 at 11:07pm
I have a two-bar spring-tooth harrow that has a broken shank.  The harrow is shown on page 237 of Norm Swinford's book.  The shanks attach with the flat side facing up and then do a 90 degree twist so at the bottom where the points attach the flat sides are pointing to the sides of the harrow. Most other harrows that I have seen do not have this twist in the shanks.  Does anyone have an extra shank or two to sell?  Thanks.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
