Proper wheel mounting "B"
dad2many View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Topic: Proper wheel mounting "B"
    Posted: 09 Jan 2012 at 9:12pm
OK, so I finally got the tire changed to the new rim and mounted back on my tractor. I'm not sure its right though. I have seen clamp blocks on the outside of the rim and the inside. I put them back on the inside as I found it and matches the other side. Also, I noticed that two of the bolts and blocks are eccentric. What is the proper way to mount and where are the eccentric clamps supposed to be located?
On another note, i found the previous owner had been running that hub loose and has worn out the hub splines. Anyone know what I can expect to pay for a good hub?
Thanks
This page was generated in 0.744 seconds.
