AC WD45 Gas
Stanley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Topic: AC WD45 Gas
    Posted: 28 Nov 2009 at 6:34pm
I recently acquired a WD 45 gas wide front.
A few questons. Serial #WD168621. Is this a '53 or '54.
There is an oil fill cap on the distributor/governor housing. Is there supposed to be oil in the reservoir or does the oil go to the crankcase? The governor does not appear to work, as the engine is either at idle or alomost full throttle. It doesn't seem that the throttle linkage is loose. Any suggestions re: the governor?
The rear rims are rusted through at the valve stems. How do I correct this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 6:48pm
The governor could be as simple as adjusting it. The best thing to do is get a repair manual. Not too tough to do. I just repaired the rims on my D17 that were rusted around the stems too. I found a decent wheel in the neighbor's junk pile and cut a couple patch panels from it. I then cut the rusted part out of my wheels to fit the patch panels and welded them in. All I used to cut with was a cutoff wheel in my Skill saw. Might be able to do it with a Sawsall as well. I've only met one guy in my life who could cut with a torch and have it look like a saw blade cut it.
The first patch can be seen if you really look for it. The second one I tack welded some "brackets" so the patch couldn't move while I welded it in. To further make the the repairs hard to find/see, I reversed each wheel and drilled the valve stem hole on the opposite side. A tiny amount of body filler on the first patch hid the repair well. The second patch only required some spot glazing to hide the grinder marks.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 6:52pm
I'd say it's a 1954, The oil fill is for the crankcase, you might have a combine governor in it. the rims can be repaired or just get new ones from a one of the guys on here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 7:49pm
The cap on the governor is for adding oil to the crankcase. Don has a good point. I don't know what combines had different govns. but maybe you have a combine engine in your tractor. Some people on here might be able to tell by the engine number which is different than the tractor number, it is stamped on the left flange of the engine where it bolts to the bell housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 9:05pm
The engine number is 45-26076-GH.
I thought maybe there should be oil in the governor housing, but I guess not.
Should oil be pumped to that area?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 10:42pm
as far as i know..  the 45 means its a wd45 block..  26076 is block serial # and G stands for gas   H is for ?????
there should be a tee in the oil line feeding the governor on a wd45 that also goes to the cylinder head and oil filter base if i remember correctly.  WC and WD dont have oil line to governor unless it was changed on late wd's
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 5:53am
There is an oil line that goes from the governor to the oil filter base and also to the engine. I assume oil is supposed to be pumped through the line. How do I make sure that's happening.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 8:06am
Start the tractor up. When oil pressure is up disconnect the line to the governor housing and see if oil is coming out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 8:29am
A few questions. Serial #WD168621. Is this a '53 or '54.
There is an oil fill cap on the distributor/governor housing. Is there supposed to be oil in the reservoir or does the oil go to the crankcase? The governor does not appear to work, as the engine is either at idle or almost full throttle. It doesn't seem that the throttle linkage is loose. Any suggestions re: the governor?
Help me out a little on the governor thing, Is the engine running away with it's self ( turning over 1600 to 1700 RPM's) or is it not giving you mid range RPM control?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 7:19pm
Don - Seems to idle okay but no mid range control.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 7:32pm
OK Stanley, We'll get it fixed! Will it hold a steady high RPM (1650 to 1730 RPM) or does it run away with the throttle opened up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 8:40pm
Don - I will have to check that. I won't be able to visit the old gal until tomorrow. I will get back to you asap. Do you have an e-mail address or should I use this forum?
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 8:51pm
That is a 1954 model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 6:09pm
Don - The engine appears to either idle or hold fairly steady at high RPM's. It does not "run away" at full throttle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 7:48pm
I just sent you a PM about this.
Don
