Allis B PTO
vpint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vpint Quote  Post ReplyReply Direct Link To This Post Topic: Allis B PTO
    Posted: 28 Nov 2009 at 5:01pm
I have a B and just got a new sickle mower which I mounted but the pulley for the mower and the PTO pulley are off by about 4 inches.  The PTO on my tractor has a collar that is 3 inches in diameter by 3 and one half inches long and then the PTO shaft is after that.  So when I put the pulley on I am about 4 inches too far back.  My question is do I have the wrong pulley or is there a way to take the PTO collar off in an effort to shorten the shaft by that much?  The collar and the PTO shaft are all one unit.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 5:11pm
It sounds like someone put an overrunning pto clutch on your pto. If there are 2 setscrews or grease zirks on it, take them out and there should be a roll pin that you can drive out with a punch. Then the whole thing should slip off of the original pto shaft.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 7:17pm
Eldon took the words right off my reply I was proof reading. It's a one piece thingie that fits over the pto shaft splines to allow a bushog to freewheel instead of shoving the tractor ahead when you push in the clutch. You don't use that thingie to run a sickle mower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 7:29pm
It is possible you have a 1 1/4 pto instead of an 1 3/8 pto shaft also. The 1 3/8 conversion would make it longer. If that is the case, you may need a different pulley for the tractor. I'm thinking Eldon and Ken may have the right answer though.
StanInLowerAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 10:09pm
I had the same issue on my B when I mounted the IND SICKLE MOWER.  The pulley was made for the 1 3/8 shaft and my B had a 1 1/8 shaft.  I got an insert type adapter from my local farm equipment dealer that decreased the ID of the pulley when I installed it so it would fit the PTO shaft.  I think the cost was about $6.  If you need one and can't find it let me know. Stan
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 10:12pm
I should have said that when you remove the adapter that is on your tractor, you might have to change the ID of the pulley to fit the PTO shaft.  Stan
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 10:29pm
Here is a picture of the insert.  Look closely and you can see it on the shaft.  I also have the Gates belt size if you need it.  Stan
AC Wilk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Wilk Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 10:46pm
Stan quick question are the two round stock / turn buckles something you made or are they factory? And what purpose do they serve?
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Yes I did paint it myself........Why do you ask?
1956 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 8:05am
For AC Wilk, the turnbuckles are AC factory equipment.  A forum member was kind enough to sell them to me at a reasonable price.  They are intended to add additional bracing to the drawbar and be adjustable as the need to tighten the belt the drive belt.  I think they were the same on the B and C.  ACGO part numbers are708021153 LH thread rod, 70802160 coupling nut, 70802152 RH thread rod.  I don't know if they are still available but you might ask.  They are listed with the parts for a B/C sickle mower.  Let me know if you need any more information about them. Stan
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 8:37am
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Wilk Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 8:21pm
Thanks Stan, as always the knowledge and willingness of everybody to help on this forum is priceless.
And thanks to GBACBFan for the pic.
1956 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote vpint Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 5:50pm
I took out the grease screw and the set screw but there doesn't seem to be a pin.  I tried pounding with a hammer and punch but nothing moves.   Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 7:21pm
Clean it up good and rotate it....there's got to be one in there somewhere.
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2009 at 11:47pm
Some runover clutches have a spring loaded release on them that releases ball bearings from the groove on the pto shaft
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2009 at 5:59am
I used a PTO coupler that used the ball and sliding collar type fastener to the PTO shaft once.  When I tried to release the ball connector from the shaft, it would not release.  I finally had to cut the connector off the shaft with a metal cutting saw.  Hope your problem is not as difficult as mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vpint Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 2:57pm
It looks like I am going to have the same problem that you had in that I will have to cut the coupler off.   Before I get the torch out, do you know how far back form the main tractor rear end I should cut so that i come close to the spot where the ball bearings are?  My guess is that I should cut at the distance from the tractor where your corrent PTO shaft has the grove?
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 10:22pm
I'm not quite sure what dimensions you need, but if you will email me at rigstlo2@peoplepc.com I will try to help you out. Stan
