Belt drive equipment questions
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Belt drive equipment questions
    Posted: 28 Nov 2009 at 4:57pm
I got a belt pulley corn grinder from a forum member about a month ago and used it that weekend and it worked pretty good.  Tried to use it again and I was having the belt fall off all the time so I gave up for the day.  My question is, is it better to use a longer belt.  The one I have is 6" wide but it's probably only about 25-30 feet long as I am only about 12 feet or so roughly from the grinder to the belt pulley on the tractor.  Also, this is a Letz grinder and right now it is just mounted to two wooden slats and sits on the ground.  I would say it has to weigh about 150-200 lbs. as it isn't easy to move it around, but would it be better to have it bolted down to the concrete in the barn floor to get better tension on the belt.  I am a novice as to the whole belt driven stuff but when this thing runs good, it grinds corn like you wouldn't believe and I use it for feed for our chickens.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 5:50pm
Well Chuck I'll take a shot at this. The first thing to do is stake the mill down in two or more places, Then place the tractor level with the mill, A longer belt will help but getting the pulleys linded up is a must. My 87 year old Dad is my go to for this kind of INFO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 5:56pm
Alignment would be the first thing that was off , but if the grinder can move at all then you will never keep alignment right as when a load is applied the unit will move to the power source .
 On something like this it seems to convert it to PTO drive would be the way to go .
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 6:49pm
You may already know this Chuck,my dad would take some metal fence posts and pound them in the ground to guide belt and keep it from falling off.Staking the unit down would help also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 8:17pm
With proper alignment. Pat's steel posts won't be necessary. I have Dad's old Monkey Wards hammermill at our showgrounds. I use 2 pieces of 3/4 rebar about 2 feet long to stake it to the ground. The longer the belt the more forgiving as far as alingment
