d17 series 2 power steering
Mr.P View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mr.P Quote  Post ReplyReply Direct Link To This Post Topic: d17 series 2 power steering
    Posted: 28 Nov 2009 at 4:54pm
i recently took off my power steering pump and reassembled it all. when i started my tractor back up, the wheels turned on there own to the right side. i cant turn the wheels to the left at all. Was i suppose to align the power steering gears? Does anyone have any idea why the wheels would turn on its own. thanks
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 5:15pm
had that happen on my D-15, turned out the lines were on backwards on the Control valve. Doesn't sound like that is problem though, can't imagine you could cross the lines up with just disconnecting the pump assy.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 6:44pm
  those pumps have to be timed  for hyd. expert
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 7:29am
the only way it could turn on it's own is if the steering valve was stuck in the right turn position. something may have gotten in the line when the pump was off and was pumped into the valve when started up
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 8:14am
I had that happen on my D-17 series lll. Inside the control valve/worm shaft unit there is an adjusting nut. This nut came loose and the shaft moved messing up the routing of the oil in the valve.
When I started the engine the wheels went to the right all the way and and I could not make them turn left.
In the center picture part # 79 {nut] caused mine to do what yours is doing.
What was the problem that made you work on the pump.
If the control valve worked fine before the pump rebuild you may have another problem that causes the same action with the wheels?????
Have someone turn the wheel with the engine off.
Watch the shaft at the control valve.
If that nut is loose the shaft will work in and out of the control valve instead of turning the sector gear. The shaft will just ride up and down the sector gear and won't turn it.
Edited by Jeff Z. NY - 29 Nov 2009 at 8:35am
