Bead breaker by RyanTN
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: Bead breaker by RyanTN
    Posted: 07 Jan 2012 at 6:47pm
Fought with this wheel/tire for several hours, truck/ramp, beat with sledge, etc w/o sucess
then saw Ryan's method, and this is the result after about 15 min's.
Ryan is da' man!
I am still confident of this;
Wait for the Lord;
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 7:04pm
Glad it worked out for you Lou!  I can't take credit for it though, I think I read about it on "the other site" a few years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 9:32pm
Hope your chain isn't longer now. LOL
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 12:29am
Grew up with them but it still amazes me sometimes what you can do with one of those jacks.  We have several on the place and they get used/abused quite often.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 1:27am
i have broken 3 of them jacks thru the years! haven't replaced them yet, but will buy another sometime! the new ones aren't as good as the older ones!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 7:42am
I basically did the same thing, but I used the tractor frame and the draw bar.  I think the draw bar is the safest way.  Yep I agree, quite a handy tool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 8:17am
A picture really is worth 1,000 words !!!
I bet a 20ton bottle jack in the same setup would work Ok ??
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 8:35am
I do basically the same thing, but using an old car bumper jack (hard to find one of those any more) under the receiver hitch of my pickup truck instead of using a chain.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 10:16am
Protrucker,
Broke many, many beads back in the 50s and 60s using a bumper jack under the car bumper.
Then, I found one of these little harbor freight bead breakers at a garage sale for $2.00.
Greatest thing since sliced bread but not quite big enuf for the larger tractor rear tires.
Tremendous leverage there!
Been thinking about building one a bit bigger for that job; not a complicated tool to make.
The last one I did, I used a heavy piece of channel iron across the top of a 20T bottle jack with chains around the tire and hooked to the ends of the channel. It was a little tricky to keep everything balanced.  LOL
Same idea as the jack shown in Lou's post..
Edited by Brian G. NY - 08 Jan 2012 at 10:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 12:22pm
Might be a little tougher to keep the chain on the jack without adding something to it.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 12:50pm
the tire maul, the truck and ramp,
and all the other trick were better
when i was younger but now i only
used them if the tire was loaded
now i used a vacuum pump i made
from a frig compressor and put enough
vacuum to suck the side down a bit
and tap it down a bit on both side
because the pump  will only take
the easy-is (spelling ) side down
as we get older we have to work smarter
B:-)     Dnoym
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 6:53pm
THERE IS A REASON THEY ARE CALLED HANDYMAN JACKS
i have even used them breaking beads with the wheel on the tractor, use the frame to anchor on the inside bead, and packing in a pickup close to use the rear bumper as a anchor on the outside bead
Edited by ky wonder - 08 Jan 2012 at 6:56pm
i like old tractors of all colors
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 8:04pm
I'll haven't found an easier way than my skid steer and a set of forks...I used to do it the hard way....
ALLIS EXPRESS!
This year:
orangeonly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeonly Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:31am
Good old handyman/farmjack. Can be used for anything.
I bought a guy one for a gift one time. He hadn't had one before. This guy was a real good mechanic. His son made fun of it when he opened it. Saw him using that jack all the time, I'd just say that jack ain't good for nothing is it.
If it ain't orange it ain't worth ownin'
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:50am
I bought my Handy Man at an auction about 12 year ago and paid $30 for it. It was an older one that looked like new. The guy next to me thought I was crazy "cause you can almost buy a new one for that". Well I have the notion that my time driving to the store is worth something along with gas used AND, the old stuff seems to be of better quality than what you get now days. Sure comes in Handy a lot!!
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:58am
That is the way I brake down tires.  You have to be carefull when working on a good tire, I have put a hole in one.  Do you take the tire off the rim with the skidloader?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 10:40am
Any front end loader with down pressure should do the trick; trouble is, not everybody has one!
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 10:51am
Skidsteer.....Eldon I think thats cheatin.....
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 10:59am
Don that reminds me of what a chiropracter told me about 30 years ago.....some people are built to work with their head instead of their body....I try to use that advice whenever possible!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 11:19am
Good point Eldon good point
1968 D15D,1962 D19D
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 11:41am
Around here we call them DeadMan Jacks. Never know when they are going to stick on you and drop whatever you have lifted up to the ground. Every one I have seen hangs sometimes even when lubed good.
I had a old 7.5' Lilliston mower jacked up one day....did realize it didn't fully click the last time.....handle flew up and hit me right in the jaw and knocked me to the ground....I have a scar from it. I don't know how it didn't break my jaw...I was in the back by myself so I'm glad it ended up not  being real bad....had to eat soft food a couple days.
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 11:51am
Kid down the road has a neat bead breaker.. dont know what its called but it clamps to rim and expands as you tighten a bolt on it with a socket wrench. works quite well but when I went to buy one for myself it was very expensive.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 1:45pm
Does it look like this?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 6:11pm
I broke 2 grader tires down today with a handyman jack and chain. They have been on the wc for at least 40 years and probably more. They were quite stiff and didn't come off the rim easy either. I feel like I got second place in a 2 man ass kickin contest.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 8:14pm
Thad, maybe you were the one that had one leg tied up?  I know how you feel, BTDT.
