XT update
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: XT update
    Posted: 07 Jan 2012 at 4:35pm
I installed the new rebuilt roosa in the XT today. She pumps. Everything is bled. Should I pull the injectors and clean them? I tried to get her running but I think she's got to be timed cause I just bolted the pump in the middle of the slots. This is the one which has set for 24 years.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 4:41pm
Ya it has to be timed, did you pull the pump with the engine at the correct timing mark?
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 6:35pm
Yup, did all that.
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 6:42pm
Just a thought, did you check the compression 1 of the 3 things to make her fire.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 6:58pm
Sorry Captain but haven't been following the XT real close.  Any white smoke out of the stack?  If it is smoking white and it is in a non-heated area it may need some assistance in the form of a whif of starting fluid.  I have always found it to be cheaper than grinding on starters and batteries, others say differant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 7:21am
OK guys I have the pump timed and the injectors being rebuilt/cleaned. They were nasty dirty and partially plugged. Their cracking pressure varied from 2600 to 3200. After they are rebuilt we shall check compression. I vacuumed out the injector holes and put a couple shots of Marvel into each cyl. Dana
