Close call this morning (pics)
jjpetrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Topic: Close call this morning (pics)
    Posted: 06 Jan 2012 at 4:26pm
Edited by jjpetrich - 06 Jan 2012 at 4:45pm
On the farm wd,wd45,180,200,7020,8010,8050,f,L2,2 b engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 4:30pm
Me and dad hauled up corn this morning with the 8010, 8050 and my set of wagons a pin weld broke.  Had about two feet before the wagon would of pulled the tractor and wagons down into a 30ft creek.  Happy God looked out for me on that one!
Edited by jjpetrich - 06 Jan 2012 at 4:46pm
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 4:40pm
Woof!, bet that was sure enough scary. Glad it worked in your favor.
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 5:46pm
Glad it turned out alright for you. My brother has 2- 450 bu wagons and last year he had one full one behind the 8070 with a new 1 1/4" grade 8 pin that broke as he was backing it in the shed. He will never again pull 2 full wagons together again.
HD16,917H,185,7050,8030FWA,8050FWA
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 8:41pm
Might put a little extra in the collection plate this Sunday.....just a thought.
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
jhid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhid Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 9:22pm
my boss was pulling a wagon with 200 bales on out of the barn with the forks and he had to back down a bit of a hill with a curve and as soon as he cut to go around the curve the front end started sliding, I was in the barn and heard him yell, it slid about 2 feet but he thought it was going through the shed. I guess it was a day of close calls
red and green are nice for christmas, but orange is all year round
http://www.canadianantiquetractor.com/tractorforum/
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 10:07pm
So glad and thank God you are OK!
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 10:07pm
Kinda like older PTO equipment; those wagons were probably not meant for a 130-180HP tractor.  Can't see what that 8000 series is, but they got a looooooooot more pull to 'em than the older say 190's that were the "big" tractors when those were built.  Just means you got to inspect things more often for stress cracks.  Really glad things turned out ok for you, and hope your posting helps someone else avoid an actual disaster.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 10:42pm
Thats the thing i would have noticed that there was a crack or something but theres a plate over where you could see it.  Going to make sure to over haul all the wagon gears with new bearings and grease.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 12:24am
jjpetrich, do you pull those wagons with a PS ?  That jolt between gears can be hard on wagon bolsters. Had the same thing happen to me.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 7:06am
Had to be a bad pin.  1-1/4 inch pin will take all a 8070 can give it and then some all day long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 7:38am
Should take  178,000 lbs. to shear an 1 1/4 grade 8 bolt.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 8:11am
Thanks for the reminder to think twice about everything we do,
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 9:22am
Had somethiong similar happen. The tie rod bracket brake free of the spindle. Makes you think.
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 1:48pm
what about those planter wheels up against the mail box post?
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 3:02pm
Years ago a guys wife was hauling to the local elevator with tractor and 2 wagons 500bu in front and 250 behind, when she scaled in and got probed she was waiting for the second wagon and they told her there was non. They hauled 6 to 8 miles, about 1/2 mile along river, they went back looking and after two trips buy saw it flipped in the river with the tires at  water level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 3:31pm
Its not the actuall pin that broke but there is a weld on top and on bottom and the top weld wore through and the play broke the bottom which allowed it to slip through.  Fixed it this afternoon and went through all bearings and should be good for a couple years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 3:33pm
Pretty sure the one wheel is off a 4 row AC planter and the heavier one is off a rake...not sure.
