Value of Allis-Chalmers 440 |
Farrell(Utah)
Joined: 11 Sep 2009 Location: Springville, Ut Points: 558 |
Topic: Value of Allis-Chalmers 440Posted: 05 Jan 2012 at 5:01pm |
I saw a decent 440 for sale today. The sheet metal and cab look straight and the engine runs well. What is a unit like this worth assuming that the transmission, rear end, etc. are good? What are the potential problems with them? Thanks.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
D-allis Iowa
Joined: 05 Oct 2009 Location: Akron, Iowa Points: 494 |
Posted: 05 Jan 2012 at 5:38pm |
It seems they are selling for about 5K.
Farrell(Utah)
Posted: 05 Jan 2012 at 7:29pm |
D-Allis you are right. There is one on Yesterdays Tractors for $4900. Thanks.
schwanman66
Posted: 05 Jan 2012 at 8:10pm |
Tractorhouse.com has 4 ranging in price from $7,900-16,500. Seems a bit high though.
1970 & 1971 190xt Series III's & 160
John (C-IL)
Joined: 11 Sep 2009 Location: Illinois Points: 1654 |
Posted: 05 Jan 2012 at 8:26pm |
The down fall of all of the 440's was their Cummins 555 engine. When it's junk it's junk, not much fixing to it.
DarrylinWA
Joined: 12 Sep 2009 Location: Amarillo Texas Points: 1900 |
Posted: 05 Jan 2012 at 9:05pm |
If it has 3 point, it is worth a bunch more I would think. $2500 to $3500 ?
Hope that helps, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
DarrylinWA
Posted: 05 Jan 2012 at 9:06pm |
I mean add that much more to the price.
one54dodgetruck
Joined: 25 Jul 2011 Location: Chehalis, wa Points: 399 |
Posted: 05 Jan 2012 at 9:10pm |
dont those tripple nickle cummins have a crank thats tapered with a key way and full of problems?Andrew
2 WDs
B B112 D14 D15 shuttle 180 185 7040 Hd7w D14 D15 185 7040 pd |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8781 |
Posted: 05 Jan 2012 at 10:07pm |
Cummins don't even make or sell parts for that engine any more, so I've been told. I read in Norm Swinford's book that Steiger would have put a Cat or a cummins in that tractor for Allis, and Allis chose the cummins. Now I am not a fanatical Cat guy, but I think Allis made the wrong choice in this case. Darrel
cornbinder
Joined: 26 Sep 2011 Location: jeromesville,oh Points: 846 |
Posted: 05 Jan 2012 at 10:18pm |
who would have known. how many bad cummins engines have you ever heard of? this was a first for me.
darrel in ND
Posted: 05 Jan 2012 at 10:22pm |
cornbinder, I know what you mean, I wasn't bashing cummins, because generally speaking they have a good product. Just that the 555 didn't pan out so well for them. Darrel
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 06 Jan 2012 at 12:18am |
Both the 555 and 903 V8's were not anywhere as dependable as the inline 6's. I'm not sure why they even built them, perhaps demand for shorter engines with lots of power. Drove both but never owned one. I'm sure someone on the forum can tell us a lot more.
Allis Express participant |
B26240
Posted: 06 Jan 2012 at 7:28am |
Maybe the point about the 555 engine could be used to lower the price ? Then what about a retrofit ? Maybe a 225 cat ? I know they are a throw away engine also but can be bought cheap. I had one in a cat excavator and it was easy on fuel
Dean/MN
Joined: 14 Sep 2009 Location: Oak Grove, MN Points: 742 |
Posted: 06 Jan 2012 at 10:15am |
If the Cummins is bad just transplant a 3208 cat in it same as a Steiger Bearcat, na 225hp. There is a ton of used ones around in old ford 8000 trucks for cheap and not hard to rebuild.
HD16,917H,185,7050,8030FWA,8050FWA
m16ty
Posted: 06 Jan 2012 at 10:26pm |
I bet the choice of engine had a little to do with CAT being competition in earth moving equipment and some farm equipment.
Wes (VA)
Joined: 12 Sep 2009 Location: Elkton, VA Points: 510 |
Posted: 06 Jan 2012 at 11:51pm |
I picked up an original sales brochure with the 210 220 and 440 in it and if you look...the 440 has a CAT 3208 in it. I'll have to scan or take a picture sometime. -Wes
D-17_Dave
Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Posted: 07 Jan 2012 at 9:37am |
Why would anyone want to take out a throw away Cummin's engine and go to all the trouble to replace it with a throw away Cat 3208. Cat as did Cummins both made some great engines. I know near nothing about a 555 but I do know most 3208's were junk when it came time to rebuild.
Rather have a 2 stroke Detroit in it. Perkin's had a V-8 diesel in the 1155's. Would that be a good swap in power to the 555? I have used a 1155, runs out nice with lots of power but the V-8doesn't lug like a straight 6. Many times pulling it down in rpm's to turn it would fall on it's face.
Yea, I can fix that.....
Kurt WI
Joined: 19 Oct 2011 Location: Cascade WI Points: 3246 |
Posted: 07 Jan 2012 at 11:11am |
Just saw one listed in WI state farmer located in IL for $20000. Its does have 3pt and very nice shape. Kurt
daughter#1
Joined: 07 Apr 2010 Location: castalia iowa Points: 110 |
Posted: 07 Jan 2012 at 2:41pm |
the 555 cummins can be a good engine, most that have bad experiences with them would of had just as bad luck with the cat v-8. I have used the 3208 in mf 1805, 903 in trucks. Our cummins rep has warned not to lug,slow idle, or over rev the one in our 440 and it will be fine. Parts are still available, did have the pump rebuilt, next will do the injectors just as a precaution.
The 555 was used in a lot of different applications, from marine, fire trucks, ag, and industrial. Engines have changed a lot over the years as we all know, my current truck has a maxxforce (man) engine which is to be kept between 1000 and 1400 rpms, the 440 is run about 2500 under load, after spending the day at 1100 climbing into the 440 and running at 2500 plus is hard, but thats what she wants. Much harder to get 440 tractor parts than the engine parts |
TREVMAN
Joined: 04 Jan 2010 Location: Regina,Sask,Can Points: 1635 |
Posted: 07 Jan 2012 at 11:09pm |
The 555 was in 555 Versatiles as well. The problem was, as Ive said before and will say again, they got overpulled most of the time. If so, they wore out. A neighbor had one, pulled 2 16.5 international discers, lasted forever. Another neighbor had one, pulled 3 16.5 discers, wrecked it. Neighbor 2 would tell anyone who would listen it was a pile of junk...Around here most repower with 8.3 Cummins, I think there is a kit to do that. Overall I think a 440 at 5-7 k is a good tractor, just dont expect to lug it to death, it wont last. My 2 cents, Trev.
Tom Miller (IA)
Posted: 07 Jan 2012 at 11:16pm |
If it was mine, I would put a cummins 855 in it at about 250hp. That was what we did when we rebuilt steigers in the late 90's.
TREVMAN
Posted: 07 Jan 2012 at 11:18pm |
Forgot to mention, Ive seen one repowered with a 5.9 cummins, and the one I really liked was a 6.7 cummins repower, looked really slick, and I think just the right amount of power, Trev
festus51
Joined: 26 Mar 2017 Location: Osage City, KS Points: 1644 |
Posted: 04 May 2022 at 11:31pm |
I know this post is old but I have 440 with 555 cummins. the rated rpm is 2800 but I pull mine at 2200 rpm and have no problems. It is my opinion and everyone has one but I think people are over reving and over loading the engine. That is where the problems start,
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
badjeep
Joined: 31 Jul 2011 Location: Mt. Hope, KS Points: 134 |
Posted: 05 May 2022 at 6:43am |
I also run my 440 at 2200 RPM, a little less power but I don't worry about that 555 going south some day. |
In the shed- 7020,7060, L2 X (2), CII, WD X (2), 200, 210, 611H, 440, Fiat Allis 345B
