WD9 Loader Cylinders
Richard (KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard (KS) Quote  Post ReplyReply Direct Link To This Post Topic: WD9 Loader Cylinders
    Posted: 28 Nov 2009 at 11:23am
We're gonna try to rebuild the cylinders on a friend's WD9 Freeman loader.  Any tips or pitfalls to avoid? I 've never tried to disassemble a cylinder, not even a tie-rod type...
Thanks for any help!!  Richard (KS)
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 12:02pm
I better subscribe and listen to the pro's here also.
tip - I decided it's a bad thing to mix 2 different cylinders even if they almost look alike, it get's kinda jerky when raised all the way.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 4:29pm
Actually, I am by no means an expert. Having said that, I have rebuilt a couple of them. Since they are of the displacement type, they are fairly easy. Four bolts to remove the compression flange (you don't need to remove the piston, in fact, I resealed mine without removing the piston/cylinder from the tractor). Use a pick to pry out the old seal. This is probably the hardest part of the job, make sure you get it all.
Some of these cylinders used chevron seals, maybe they all did origionally, I don't know. Finding the chevron seals hard to come by I just use rope seal, pack it in and slowly and evenly snug down the compression flange. HTH
Edited by LouSWPA - 28 Nov 2009 at 4:30pm
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 5:57pm
Ours were leaking when we brought it to town.  Dad decided to try power steering sealer, and it worked!  Don't know how bad yours leak, but ours were pretty bad.
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 6:05pm
If it V ring packing they can be found in any hyd. shop , most are split ring so the ends are cut at angle and lapped over . You can use a larger size and cut it or get a kit that is made for it. Sometimes another ring can be added if the old packing is just compressed to far.
 New style uses a formed 0 ring or a square type ring, be sre to install any spacer ring also to keep the same tolerances .
 A small amount of oil has to be left on shaft so do not overtighten any glands to try to keep shafts completly dry.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 6:06pm
Lou, You are right on! And that will make you a PRO. in my book. lol
If I can find the name of the place in KC MO. They have all the packing for them. Dang now I have to think and that's going to hurt. LOL
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 6:20pm
I got new chevron packings through work for other cylinders I have rebuilt. I believe the cylinders on a Freeman loader would take the same type packing. I think they are available from Motion Industries. You just have to have the 2 dimensions, outside diameter of the rod, and the inside diameter of the packing retainer. If there are any scratches or gaulding or even heavy rust on the cylinder rods, the seals will not hold up. I made a new rod for the Build a B cylinder and have made rods for others like my Allis remote cylinder. Coke makes a good point too. The packing can not be too tight as to make the rod dry. The packings have to weep enough oil to lubricate the rod and packing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard (KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 10:02am
Many many thanks for all the very helpful replies!!  We'll have a go at it this morning.  Apparently we have seals but I have no idea yet what type.  Thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 12:42pm
Well I got the name of the Co. Swan Engineering & Supply Co.
