OT, (a little) Ground-Driven PTO
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Topic: OT, (a little) Ground-Driven PTO
    Posted: 28 Nov 2009 at 9:11am
May be a dumb question...
Some Allis, Ford & MF tractors (others, I'm sure) have a Ground-Driven PTO option or selection.
What was this used for?  Raking? Tedding?
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 9:25am
Those are the most logical uses. I suppose it could be use to drive a three point planter or drill too. My MF-135 manual says, "This feature is very desireable when operating implements which require operating speed proportional to the tractor forward speed, i.e., PTO driven Side Delivery Rake, Lister Planter, etc." It goes on to note that it better be shifted out of gear when backing the tractor in case the implement won't survive reversing the PTO shaft. But that also hints it might be a handy way to reverse the PTO to cough out a clog in some processing implement.
I have seen such a PTO driven MF rake but not anything else that I noticed. I used a PTO driven planter a few years, but it was driving a fan and needed constant engine drive, not ground speed proportional.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 9:39am
That might be what is needed for the Dearborn rake my great uncle had. I used it once on the 8N and ran in third at an idle and it still beat all the leaves off the hay and twisted it into a rope.
FRANKO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FRANKO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 10:55am
I think "ground driven" is a term left over from the animal power days because horses or oxen did not have a rotating shaft sticking out the back end!  Any power needed to rotate something such as a side delivery rake needed to be taken from a wheel touching the ground.  For tractors the PTO speed is proportional to engine speed, and ground speed is proportioal to engine speed, therefore PTO speed is always proportional to ground speed.  You can change the proportionality constant by changing transmission gear ratios.  If the PTO shaft is driven from a connection on the output side of the transmission, then only one ratio is available and it would allow the PTO to turn backwards when the tractor reversed.  That must be the new definition of ground driven!
TomSEOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomSEOH Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 5:31pm
Ground driven PTO is exactly what is says it is, PTO is directly proportionate to wheel speed and yes, if the tractor is placed in reverse it will turn the PTO in the opposite direction. I have owned several tractors with the option and about all i ever used it for was to unplug a haybine or an old type (closed throat round baler)   Tom
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 6:46pm
What different make of tractors was that available?
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 8:25pm
My BIL has a Massey with it.  I don't remember the model number but it is probably like late 60's or early 70's built.
StanInLowerAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 8:18am
I have a MF 135 with this feature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 9:52am
But Franko, in a modern tractor with say a dozen speeds forward (like my 1968 MF-135) there are that dozen ratios from ground speed to PTO and the standard PTO speed is defined to be 540 in this case with the engine at 1850 RPM which is indicated on the tachometer as PTO speed. The MF-135 regular PTO is not driven by the transmission, but has its own clutch, shafts, and gears totally independent of the transmission but often concentric with transmission parts like the input shaft and the cluster shaft. That's true whether the two stage clutch on the clutch pedal for "live" PTO or with its own hydraulic clutch for "independent" PTO.
The ground speed gear position is driven by a gear on the differential pinion shaft and is defined to turn approximately one revolution per 20" of forward motion. That will be affected by the choice of rear tires, whether 14.9x24 or 12.4x28.
I had a couple city boys on the hay rack one day and they shouted to slow down because I was putting bales on the rack faster than they could stack (comfortably). So I held the engine speed constant and shifted down a gear. They still weren't happy so I shifted down another and another. When I was down to 1.5 mph at PTO speed and they were still grumbling, I paused and had a little chat pointing out that the baler needed PTO speed but that I had cut ground speed by a factor of 3 so surely they weren't being overloaded by bales. They hadn't checked ground speed and bale frequency, they just listened to engine speed. We baled successfully that time and several more without doing them harm. I paid them a buck over minimum wage too.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 11:25am
Originally posted by FRANKO FRANKO wrote:
.... You can change the proportionality constant by changing transmission gear ratios.  If the PTO shaft is driven from a connection on the output side of the transmission, then only one ratio is available and it would allow the PTO to turn backwards when the tractor reversed.  That must be the new definition of ground driven!
I don't quite understand the 1st & 2nd sentences... esp. "If the PTO shaft is driven from a connection on the output side of the transmission..."
Does this imply there is some other connection for Ground-Driven PTO that is NOT on the output side (bevel pinion gear shaft) and thus would be proportional to the transmission gear selected......or ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 11:45am
As we al know the standard PTO speed is 535 RPM. Some MF models  added a second gear for the PTO. Which is related to the ground speed. If you change the ground speed by shifting the transmission gear then the speed of the PTO changes.
I think MF is the only manufacture that had this. That's why I asked in the earlier post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 12:34pm
Gatz, some PTO were driven directly off the second shaft of the transmission. Ford N series for example. That second shaft always turns at a fixed ratio from engine speed, but ground speed depends on which gear is connected to the differential. So that in Frankos mind allows different ground ratios depending on the drive gear. But at what sensitivity. Say at PTO speed in 1st gear (like an 8N) at 2 mph, that is about 10,500 feet per hour, 32,400 revolutions of the PTO shaft (540 x 60) so that is about 3 revolutions per foot of travel. In road gear at 12 mph, it would be about a revolution per foot of travel, not far from the MF-135 standard.
Gerald J.
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 3:34pm
My uncle's AA8610 has an "economy" setting that seems to be ground driven in some fashion, but I have never seen it used to know what sort of speed differences could be attained.
DreaminGA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DreaminGA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 4:11pm
Just to mix things up a bit, Kubota and other import tractors do have PTOs that are affected by transmission gear selection. I'm not sure about the newer ones, but the older Kubotas and Yanmars seem to have this. Some of those have multiple speed selectable PTOs to help match PTO speed with ground speed. Really affects performance and horsepower with flail mowers and other high load implements. Dream.
It wasn't me! It was a short, fat, tall, skinny guy that looked like me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 4:22pm
thanks for all the answers...it makes a lot more sense now.
All this discussion just reminded me of an incident many years ago when I was a young kid combining oats for a neighbor with his WD45 and 60.
He had told me to use the hand clutch if there was a need to stop, and of course I knew this as we had a D17.
Musta got real nervous when coming through a ditch and pushed in the foot clutch to slow down....totally forgot the hand clutch.
Man, I caught hell for doing that....although to this day, I don't know why he got so PO'd
This was my introduction to "ground-driven PTO"  lol
