WD45 HAND CLUTCH
mark vaughn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark vaughn Quote  Post ReplyReply Direct Link To This Post Topic: WD45 HAND CLUTCH
    Posted: 02 Jan 2012 at 9:21pm
I have a early 1954 model WD45 tractor. What parts do i need to replace to keep the hand clutch  engauged?  Also will a 3 disc clutch assembly fit in place of a 2 disc assembly?  Thanks  Mark.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2012 at 10:23pm
If the linkage is all hooked up at clutch, engauge clutch and rotate until you see the snap ring ends. Remove snap ring, disengauge clutch and rotate the flange the snap ring was on about 1 inch, engauge clutch and install snap ring.   MACK
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2012 at 7:36am
Starting with tractor number WD45-165036, a three disc clutch was fitted into the same space as the two disc.
Here is a link to TomMN's site which shows all of the components of the wet (transmission) clutch:
When you open up the compartment, the proper adjustment on the discs is a cumulative clearance between the clutch plates of 0.065".  You can measure this with a drill bit or Allen key.  If you have more clearance than this, gradually remove brass shims from the three packs so as to keep spacing equidistant around the periphery.  The shims are only a couple thou each and get so compressed that the packs look solid, but they are not.  Don't drop a pack or you will be draining oil and going fishing.  If this fails to fix the problem, try Mack's rotating tip.
It this still doesn't work, you may have broken parts in the clutch pack and you are looking at splitting or stretching the tractor to disassemble the pack or replace it outright.
You want to make sure up front that your problem is not caused by cumulative wear in all of the pivot points in the linkage outside of the chamber.
If you have ever run the clutch without sufficient oil for any length of time, you probably have damage inside.
