Too much oil pressure?
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: Too much oil pressure?
    Posted: 27 Nov 2009 at 11:44pm
   Been messing with a completely overhauled B that was showing a maximum of 10 lb reved up on a good S&W gauge. On a white face Allis gauge it almost didn't get in the normal box. Split the tractor again and replaced the oil pump relief ball and spring. The spring was almost worn thru from rubbing the housing. Ball didn't look that bad. Didn't have the right replacement spring and the one used was a bit stronger. Now it pegs both gauges at fast idle and the S&W has a 50lb range.
    Is this a case of more is not better?  Don't really want to split tractor again.
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 12:09am
I wouldn't say that it would hurt the running/internals of the engine, but I would worry about something starting to leak from a blow-out such as the gauge, or the gasket at the filter base.  Or elsewhere that that pressure will be applied.  The pump gasket itself may develop a leak?? from not being able to unload...  not really sure how much it would be able to stand, but if it was mine I would probably change it again.     -Wes
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 5:53am
I did the same thing a long time ago. It worked fine til the weather started cooling down and the oil filters started turning in to basketballs. You might as well go back and fix it now and get it over with. The low pressure won't hurt it as long as you use a good grade of oil. I would run Rotella oil in it because it takes alot more heat to thin it out than most oil. My problem started when I put on an 80 lb S-W gauge and it wouldn't read anything when it got hot. The normal range is only about 15 lbs. If it has good pressure when you first start it up it will be fine.JP
Edited by Jack(Ky) - 28 Nov 2009 at 5:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 6:26am
Who has the correct replacement parts to overhaul B/C/CA oil pumps?
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 8:55am
Ken:
On most engines, that wouldn't be a bad problem but the B/C/CA engines are an odd duck when it comes to the oiling system.  The rod and main bearings only get what leaks past the relief valve, so it is not a bad thing to have leakage at the relief valve.  The gauge just indicates the pressure of the oil going to the rocker arms and filter, so it is really just an indicator of whether the pump is working.  Regarding where to buy the springs, I have had good luck with Sandy Lake Implement.  I don't remember them being outrageously priced.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 11:00am
I thought the rods only got oil from being sprayed through space from holes in the camshaft.
Where are you  Dick L ?
Gary
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 3:08pm
You are correct Gary, but the heavy spring keeps the oil from getting around the ball to get down the center of the camshaft to get (sprayed) onto the rods. The oil would be shut off to the camshaft bearings which in turn shuts the oil off to the mains.
The assembly lube will not last long with the heavy spring. At 50 pounds pressure some oil might get by the ball but not much with a a low volume vane pump.
Edited by Dick L - 28 Nov 2009 at 3:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 3:36pm
Well B751 got split and is back together and the oil pump is now reading smack dab between the N and R in NORMAL. Put the old spring back in with a little dab of stretch. Glad I asked and thanks a bunch for expert advice. I sorta rembered awhile back DickL explaining how the oiling system in the small AC 4 cyl engines works and figured they were designed for low pressure readings at the gauge  for a reason.
weiner43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weiner43 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 3:47pm
I put a stronger spring in a Mopar 340 once and blew the filter right off the engine.
God bless our troops and the United States of America.
Pick your rut well, you may be in it a long time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 6:13pm
Thats the difference between a full flow system and a by-pass system . On newer engines all oil from pump hits the filter first then to engine , in by-pass only excess oil is filtered. Most full flow will bypass oil if filter plugs but the can on them will only hold so much pressure.
