Where's the drain for the hyd fluid on a 190XT? |
Post Reply |
Dwayne TX
Silver Level Joined: 11 Sep 2009 Location: Texas Points: 221 |
Posted: 27 Nov 2009 at 9:31pm |
I've looked in two manuals and it's pretty unclear. I sure don't want to drain the wrong fliuid!
Dwayne TX
Since that drew a fat zero, how about this?
Are the final drives and the transmission fluids part of the same reservoir? |
Big Hunter
Bronze Level Joined: 12 Sep 2009 Location: maryland Points: 30 |
bottom of the torque tube
Big Hunter
no
Joe(TX)
Orange Level Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
There are 2 drain plugs for the hydraulic fluid. One is in the PTO box and the othe is in the housing that the suction tube connects to.
Each side final drive has a drain plug on the outside of the drop boxes. There is a drain fir the center on the back left by the lift.
There is also a drain for the transmission behind the battery box.
I hope I got all this right, I'm going on memory.
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 8153 |
Joe Tx, is right on it, but the final drives have gear oil in them, they drain at the bottom of each gear box, powerdirector has 2 plugs , hyd. oil, trans has one pretty much in the middle underneath the housing, hyd. oil in there too;
waltw
Bronze Level Joined: 17 Sep 2009 Location: williston Fl Points: 39 |
4 separate oil compartments, torque tube ,transmission,right final drive ,left final drive. hydrolic oil is in torque tube, it has 2 drain plugs. First is in crossover piece it has 1.5" pipe coming from filter on right side of tractor, it also has same size pipe going to hyd.pump on left side of tractor. second plug is in pto clutch housing. Pto housing is forward of crossover piece, both bolt to bottom of torque housing. transmission has two drain plugs first just behind where trans. housing bolts to torque tube. second faces to rear at lower left corner of trans housing just under lift arm housing |
Post Reply | |
