Solution to the D-17 air heater bushing
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: Solution to the D-17 air heater bushing
    Posted: 31 Dec 2011 at 5:03pm
I have talked to a fellow that has rebuilt these heaters before, and Chad was on the right track with the nylon bushing. This fellow described to me that he used the insulation from an extension cord. If you have everything right and not grounded to the housing, the stud will  not get hot. I fixed mine with a piece of insulation from a 00 battery cable. Then I took cables and hooked it up to a battery. The element got hot and the stud did not. So I guess the ceramic bushing might work for a longer lasting fix, but insulation off of a battery cable worked also.  Dave.
