WD front "axle" weight
maurice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maurice Quote  Post ReplyReply Direct Link To This Post Topic: WD front "axle" weight
    Posted: 31 Dec 2011 at 4:40pm
I have WD tricycle with two wheels on front.  Before I un-bolt the tricycle front away from the side rails, does anyone have an estimate of how much it weighs?  I'd like to be prepared so I can avoid injury to self!  I plan to support and block up the side rails and rest of the tractor, and there is no engine nor radiator on it at this time.
Thanks!
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 4:56pm
Hate to state the obvious, but It's gonna be mighty top-heavy. Hope you plan on using a hoist of some kind for help. As far as weight.....guessing around #150. I'm sure someone else will chime in with a better idea.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 5:13pm
I'd say north of 150.  I can manhandle 150, but that thing was more than I could get off the ground.
AaronSEIA
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 6:16pm
I used the engine lift on mine and it worked pretty well. It's really more than you would want to man-handle.
bryan/silex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan/silex Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 8:30pm
yes it will be top heavy, very.  Use a hoist to support it, cause it will want to flop over on  you. dont need to mash any toes or anything else!
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 11:18pm
if you remove the nose steering fixture the way john is removing it (which is pretty much the way to do it) it will weigh pretty close to 175-200 lbs.if you have fluid in the tires you are looking at well over 200 lbs plus...
Post Options Post Options   Thanks (0) Thanks(0)   Quote maurice Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 5:52pm
Thanks everyone!  I hope to get out to the barn soon.
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 8:19pm
There may be a significant difference in the weight of the assembly, depending on the SN of your tractor. In the OM for the WD 54 two way plow it states that front wheel weights should be used on tractors prior to SN 71438, except tractors equipped with the wide front axle. I have read on this forum before that the WC pedestal assembly was much lighter than the WD assembly. Maybe the WD's prior to SN 71438 used the same casting as the WC.
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 9:49am
There seems to be 3 weight # for these. The early wc ones are #120 the wc/wd ones are #180 and if you get into the wd45 they were #320. A wide front is about #350. I swaped out the 45 one for a early wc one and lost #200 of the nose of the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote maurice Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 7:40am
Thank you everyone!  I remembered that I made this a few years ago and since it was built to disassemble to store in a small place, it was "out of sight out of mind"!  I tested by lifting whole front of tractor before unbolting from frame.  Then took off the front wheels.
Unfortunately, 3 of the bolts sheared off:
That 4th hole has been drilled and tapped for an oversize bolt.  The other side has a similar oversize hole but had no bolt.
I remember some tips for getting these out - heat then melt parrifin or wax onto it, or penetrating oil, or drill and tap, or place a washer then empty nut then weld to the broken stud, ...
Also, the "bearing" or hub that both front wheels turn in (my book calls it "spindle block" -I&T Shop Service AC Shop Manual) wobbles when in the air.  Is this normal or bad?
Based on your experiences, any tips?
Thanks
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 9:27am
Cool lifting rig- I like it!
Weld a nut to 'em... let 'em cool, zap 'em again for a few cycles...  they'll back right out.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 11:41am
Certainly not normal; could be bad or maybe not too bad.
If the shaft is worn, either where it passes thru the bearing or where it goes into the "block", you have a problem. If the bearing itself is loose and/or worn out, not such a big problem.
I bet you've torn it apart by now and know exactly what you've got?!
Post Options Post Options   Thanks (0) Thanks(0)   Quote maurice Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 3:06pm
Thanks for the compliment Dave!
I'm wondering how deepy it's seized.
I have not got it torn apart yet.  This book does not show a bearing, which I forgot to post earlier...
Another delay to my original project!   :)
