Unstyled manifold?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Unstyled manifold?
    Posted: 30 Dec 2011 at 7:31pm
Did unstyled wc's ever have a straight up manifold? Mine is not but just asking. Mine is a gas only with no starting tank. I ruined mine in the blast cabinet. It was paper thin between the intake and exhaust and I ate through on both sides.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 7:44pm
Not that I know of from the factory but I never saw an unstyled without a starter tank either. A lot of them had replacement straight up manifolds when a new one was needed and that is all that the dealer had to offer.
Edited by CTuckerNWIL - 30 Dec 2011 at 7:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 7:48pm
Thanks Tucker. I figuared that would be the case. I'm a little worried about buying another used one and having the same problem.
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 8:04pm
Does anyone know the year when Allis switched from the side-shooter manifold to the through-the-hood manifold and muffler?  My 1940 model has the side-shooter manifold.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 8:08pm
I always thought it was 1948 when the WD  came out, then I saw a precision model WD with a side shooter manifold. ????????? I guess model makers aren't always right.???
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 8:27pm
back home in ohio our first tractor was a 42 wc  that had the side shooter. scorched the paint up pretty good there around what ever pipe we were runnin that day.....
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 8:52pm
Parts book shows straight up starting with engine #106509 which would be approximately 1940. Before that it was side shooter and on all low octane engines.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 9:02pm
I had a 39 WC with straight up manifold. Bob
