Spark plugs
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Topic: Spark plugs
    Posted: 30 Dec 2011 at 9:11am
I have a 1957 WD-45 gas and would like to know the best sparkplug for this tractor. Brand?Number? Heat range? I think I've asked enough questions!! Thanks in advance.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 9:22am
Check "spark plugs" and the rest is easy to follow.  You can probably do similar for most any brand on their web page.  If you don't work your tractor hard, you might consider going up a heat range or two.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 10:04am
AutoLite 295 or 303
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 10:51am
Not Champion.
Gerald J.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 11:02am
i like ngk b4 for stock stuff but some like the autolite 295 lawnmower plug
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 11:09am
Originally posted by Gerald J. Gerald J. wrote:
Not Champion.Gerald J.
Why??
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 12:39pm
Champion plugs are anything but a champion.  I like the autolite 303, or the equivilent ACDelco.
bryan/silex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan/silex Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 12:45pm
I use champions in all my tractors, don't see any trouble with them. Hear people complain bout them all the time nobody ever realy said why tho.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 12:48pm
have you guys ever thought about using a .460 reach protruded plug over the 3/8 the allis head has a built in anti fouler for distillate but on gas today getting more of the plug exposed is a plus in my opinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 12:51pm
Not Champion.
Gerald J.
Ditto.  They don't work nearly as well in my car as NGK and I had considerable trouble with Champions in the tractor.  The Champions always fouled out quickly. Perhaps it's a matter of finding the correct heat range. I've had much better luck with AC and Autolite.  That's all I'll say.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 7:14pm
When we sold them we loved the AC 45, 47, and 48, depending on the shape of the engine.  However, now the plug of choice if the Auto Light.
Check with SteveNJ.  He will know the right one.  I think 303, 295 but am not certain.
Good Luck!
Bill Long
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 8:12pm
I've had bad luck with Champion plugs failing "prematurely" to say the least. My Dad used to say Champion doesn't make spark plugs they make trouble.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 8:24pm
Anything of the right heat range will work in these 1400 rpm engines. Mine runs on used AC44 out of my 350 camaro engine. Runs like a hound and starts in any weather. We did the same thing 40 years ago when the tractor worked all day.
oldchalmersiron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldchalmersiron Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 8:42pm
I used Autolite 295's in my WD and they worked very well.
Richard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2011 at 8:46pm
I use Autolite 295 in my '45.  Champion plugs foul out and my '45 isn't an oil burner, it doesn't even smoke when it's started.
