11000 MKII or not???
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Topic: 11000 MKII or not???
    Posted: 27 Dec 2011 at 6:54pm
OK folks, so I have been thinking this hole time we have an 11000 Mark II engine in the shed, but when I looked at the tag, it doesn't have the MKII stamped on the end.  The engine has the injectors on top, and no pre cups.  What do we have?
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 11:23pm
which fuel pump? What does the tag,if any, say? Do you know what it came out of?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2011 at 10:50am
The injection pump on one of the engines is a roosa master, the other one has a Bosch.  Both are stationary power units. The one with the Roosa came factory in the Farmhand tub grinder.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2011 at 11:06am
The one my brother had in HD11B had P/Bosch. Had intake valves with  "locaters" 'cause they had a chunk on underside of head to direct air-wierd huh? AC went away from that later so @ O/H they were replaced with "normal" valves. I think it was only rated at 140hp,maybe less? Would out work the 6C Cats we both had ran.
This page was generated in 0.251 seconds.
