Tank sealer and fuel tank cap
Freighttrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freighttrain Quote  Post ReplyReply Direct Link To This Post Topic: Tank sealer and fuel tank cap
    Posted: 27 Dec 2011 at 4:11am
What tank sealer would you guys suggest?I want to pull my I600 tank out since it seaps fuel around the bung at the bottom.Doesn't look real bad inside but you can see spots of rust.THinking it is a weld leaking since it is damp wet but not drooling wet.I also where can I find a replacement Cap?RIght now the cap consist of a cut off spray can as the cap is gone.Looks like it had a latching flap style once.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 4:40am
I would take it out and clean off the paint and find the leak.
Alot of times it a rust hole just getting started.
If you clean the area reaaly good with a wire brush on a drill and wash it down good with some acetone JB weld might be the way to go.
JB Weld also has a product called Waterweld and I think it can be applied to a gas tank that is wet with gas and still leaking gas.
Check it out.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 8:37am
i use RED-KOTE it realy works great
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 9:13pm
I have used JB and Red Kote with good results. I also use Seal All, it comes in a tube and will seal wet gasoline. It is available at most auto parts stores.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 1:26pm
POR 15
donw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donw Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 2:49pm
Ditto on the POR-15 tank sealer
Don in WA
This page was generated in 0.309 seconds.
